Two VPN tunnels on same device with same protected networks
There is a remote site that wants me to set up two separate VPN tunnels with the same internal IPs at each end. EG
Local Network = 10.212.170.201/32, 10.212.170.202/32
Remote Network = 192.168.0.0/24
I currently have a tunnel for the above between:
Remote End Point = 111.93.152.186
Local End Point = 198.205.115.252
They now want to set up a VPN for the same networks between:
Remote End Point = 115.115.130.34
It is my understanding that the Cisco ASA 5520 cannot do this. The only way I've seen this done with Cisco hardware is to use two ASAs but there may be a way to use route costs or some other trickery to make it happen.
I am open to suggestions.
Philip D'Ath
Is this for a backup?
In so, specify the second remote end point as a "backup" to the peer in the first VPN.  Only one will be active at a time - but it will failover if the first VPN dies.
Philip D'Ath
Thank you for your reply.
Yes, it is for a backup.  The remote site  is in India (insert rude joke about Internet quality and cheap hookers) so redundant connections are important.  I'll try adding the additional addresses to the relevant cryptomap and see how it works.
