vpn client does not work right
jeffliu
Community Member
I have a pix 506E with 6.3(5)connecting to a DSL line. When I initilized a vpn client and connected to a vpn 3000, it seems to be authenticated but I can't access any resources that are behind vpn 3000. With a router, it works fine. What I should do on pix 506E to get vpn client (4.8) work right?
Thanks in advance!
Jeff
a.hajhamad
Level 7
Level 7
Hi Jeff,
You have to check the following protocols and ports.
- Protocol 51 (AH)
- Protocol 50 (ESP)
- UDP ports 500 & 4500 (For ISAKMP traffic).
I hope to be helpful.
Please rate if it does.
Thank you
Abd Alqader
