VPN Problem or flash problem?
gjarboni
Community Member
I have an ASA 5505 running 8.2(5)58. I recently had a problem with the Anyconnect VPN. It would hang for about 1 minute then fail about 66% of the time with the message "Failed to get configuration from secure gateway. Contact your system administrator". 33% of the time it would succeed (still with the one minute delay).
I switched the FQDN used by AnyConnect and called it a night. Later I did some troubleshooting and realized that it was only Mac's that experienced the problem. I tried to do upload the Mac OS X package (replacing the existing one), but my Mac rebooted and the upload was cancelled deleting the file. At this point the problems went away.
I successfully uploaded the Mac OS X package and the problems did not recur.
So, my question is whether this is a VPN problem or a file system/flash hardware problem. The file system has three file system check recovery files. The output from "show flash"is below. I also turned on all of the file system debugging and didn't get any error messages, but during the 1 minute delay there was no file system activity. I can post this as well.
fsck doesn't return any information and didn't fix the problem when it was happening.
During my troubleshooting, I made no configuration changes. That's what makes me think this is a flash issue (software or hardware, I don't know).
Any ideas? Thanks for reading, Jason M.
--#-- --length-- -----date/time------ path
207 196608 Jan 01 1980 00:00:00 FSCK0000.REC
208 8192 Oct 29 2007 16:43:16 crypto_archive
209 32768 Jan 01 1980 00:00:00 FSCK0001.REC
211 8192 Jan 01 1980 00:00:00 FSCK0002.REC
212 8192 Mar 09 2018 05:10:50 syslog
229 0 Mar 09 2018 05:10:50 syslog/LOG-2018-03-09-051051.TXT
213 2680 Nov 29 2007 19:55:40 config.works.20071129
214 3647 Nov 30 2007 15:21:34 config-testing
215 15464448 Feb 05 2016 20:59:30 asa825-58-k8.bin
216 12824034 Mar 09 2018 09:45:24 anyconnect-macosx-i386-3.1.12020-k9.pkg
217 8192 Jan 01 2010 13:02:58 log
219 8192 Jan 01 2010 13:03:18 coredumpinfo
231 43 Jan 01 2010 13:03:18 coredumpinfo/coredump.cfg
220 3203909 Mar 31 2010 16:44:28 anyconnect-win-2.4.1012-k9.pkg
221 5209423 Mar 31 2010 17:20:26 anyconnect-linux-2.4.1012-k9.pkg
222 4832344 Mar 31 2010 17:20:42 anyconnect-macosx-i386-2.4.1012-k9.pkg
223 15390720 Dec 07 2015 21:28:06 asa825-k8.bin
224 17902288 Dec 17 2015 06:34:18 asdm-647.bin
225 38495347 Dec 17 2015 07:39:40 anyconnect-win-3.1.12020-k9.pkg
226 12778760 Dec 17 2015 07:44:00 anyconnect-linux-64-3.1.12020-k9.pkg
227 11069389 Dec 17 2015 08:29:16 anyconnect-linux-3.1.02040-k9.pkg
255426560 bytes total (117227520 bytes free)
0 Replies 0
