I have configured a lan-to-lan tunnel between a Cisco VPN3020 and a Check Point firewall. It worked correctly until today. The tunnel seem to be OK but the connection through it works just sometimes. I obtain this log in the VPN:
Dec 4 16:24:03 [172.29.1.2.2.2] 546125 12/04/2006 16:24:02.890 SEV=4 IKEDBG/97 RPT=668 (peer IP) Group [L2L:XX] QM FSM error (P2 struct &0xa5327c0, mess id 0x793ac9bd)!
We didn?t do any change in the configuration.
Any suggestion?
