Admin Authentication on WSA using LDAP
Michael Pare
Visitor
I'm trying to configure admin authentication on our WSA S170.  I've had this working for years on our ESA S170 no problem and was delighted when I saw that this was added in 8.5.
We are running AsyncOS 8.5.3-069.  Despite the lack of documentation for this in the User Guide, I thought I had it figured out:
Under Network->Authentication
Created and tested LDAP authentication realm OK
Created External Authentication Query under that realm, it tested OK.  User and group queries worked fine.
Under System Administration->Users->External Authentication
Enabled external authentication OK using LDAP, selected my LDAP External Authentication Query fine.
I added the group names and mapped them to roles on the WSA
Log out and log back and try logging back in using my AD admin account - no go.  I tried my AD non-admin account - same issue, no go.
Both of my AD accounts are in groups that I mapped in the last configuration step above.
Despite having added this feature - I have not been able to find out a whole lot of documentation on specifically how to implement, and miss any gotchas.
Attached is a screen shot.  I copied this field for field from my ESA.  The only change I had to make to get the tests to work was the group membership query string I had to change {u} to {dn}
Our network security auditors don't like seeing shared, local accounts in use for our network infrastructure so I'm hoping to have this feature working before our audit next month.
5 Replies 5
I think you want memberof for the query string to tell if a user in the group
             (&(objectClass=Group)(memberof={dn}))
This is my group query from my ESA...
(&(memberOf={g})(proxyAddresses=smtp:{a}))
I think I found a bug in this:
If you go to your ESA and test the external auth query, specifically the group membership, it will show doing a query with the login you enter and then doing the group query with the DN of the login.
On the WSA it just uses the login you entered again...
I managed to reproduce this issue in my lab while using “(&(objectClass=group)(member={u}))” for ”Query String to determine if a user is a member of a group:” configurations in WSA. Can you please use “(&(objectClass=group)(member={dn}))” instead ot see if it helps?
Hey Tao,
That worked... But am I right in that the WSA should work like the ESA does?
Ken
Hello Ken,
I know that part looks similar for WSA and ESA. However actually they are different from the back end code level. As option "dn" works for WSA, it looks more like the design rather than defect.
Hope it helps.Please rate or mark the question as answered if this helps.
