Allow WEB access for a specifed users
petrutz_21
Level 2
Level 2
Hii,
I need a way to configure a 2801 Router for allowing some internal users to access a specifed list of web pages. For example i need that the user with ip 192.168.1.50 to have acces just to www.xxx.net and www.xxx.com and some other clients to have full access. It's this possible? And if it's possible i need a way to do this.
The IOS version is :
1. Cisco IOS Software, 2801 Software (C2801-IPBASE-M), Version 12.4(16b), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 20-Dec-07 03:43 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
System image file is "flash:c2801-ipbase-mz.124-16b.bin"
Cisco 2801 (revision 7.0) with 114688K/16384K bytes of memory.
Processor board ID FCZ123212X3
6 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
I have made this conf :
class-map match-any AUTHORIZED_URLS
match protocol http url "*.xxx.net"             /* also i have put host ...
match protocol http url " *.xxx.com"
ip access-list extended RESTRICTED_USERS
permit tcp host 192.168.1.50 any eq www
class-map match-all USER_URLS
match access-group name RESTRICTED_USERS
match  not class AUTHORIZED_URLS
policy-map URL_POLICY
class USER_URLS
drop
interface Vlan1
service-policy input URL_POLICY
but this is blocking all the web access on the client with 192.168.1.50.
Luis Silva Benavides
In order to accomplish what you are looking for, we will need to upgrade the feature set to advanced-security or something that support FW features
Then you would be able to follow this great configuration guide and accomplish your goal!
https://supportforums.cisco.com/docs/DOC-23340
Luis Silva
"If you need PDI (Planning, Design, Implement) assistance feel free to reach"
http://www.cisco.com/web/partners/tools/pdihd.html
Luis Silva
