Change Web Interface Certificate on WSA
CiscoFSYR
Frequent Visitor
Frequent Visitor
Let me preface this question by saying that I'm not asking how to install an SSL for HTTPS Proxy for Transparent Redirection. I've already done that and it's working.
What I would like to know is how to change the SSL certificate the appliance is using for the web interface.
e.g. When I browse to the device in Internet Explorer (https://%FQDN%:8443), I get a 'Problem with this website's security certificate' error because the appliance is using the Demo Appliance cert for the web interface.
How can I replace the Demo Appliance certificate on the web interface so this error doesn't happen?
18 Replies 18
Hi @erik
can you please share the output of step 11 ?
Amirhossein Mojarrad
++++ If you find this answer helpful, please rate it as such ++++
@amojarra
In step 11, I select the only PEM certificate I uploaded in Web UI certificate management.
After that, if I choose N to add intermediate cert, I got this error
But the Web UI still picks up the old cert.
Issue solved. After intermediate certificate pasted and certificate updated successfully(the second screenshot), at the 5 options menu, we should hit Enter(There is no save/commit option here ), and then input commit. I used to click ctrl+c to exit this menu then entered commit and got 'no data to commit' error.
Thanks Cisco, you made the life so easy...
amojarra
Thanks for the Update @erik.lei
we are so happy that the issue has been resolved 🙂
