Cisco Ironport370 WSA AD Integration issue
Nishit Bhosale
I am trying to create Authentication realm using NTLM. I am getting following errors when trying to join domain.
Error - Computer Account creation failed.
Failure: Unable to resolve 'abc.example.COM' : Unknown hostname
Failure: Unable to resolve 'xyz.example.COM' : Unknown hostname
Failure: Unable to resolve 'ghd.example.com' : Unknown hostname
pl help to integrate AD with WSA.
Nick
Tao Yang
Please run nslookup command in WSA CLI to verify if WSA can resolve the IP of those hosts.
WSA> nslookup www.google.com
A=173.194.72.106 TTL=30m
A=173.194.72.104 TTL=30m
A=173.194.72.103 TTL=30m
A=173.194.72.105 TTL=30m
A=173.194.72.147 TTL=30m
A=173.194.72.99 TTL=30m
Tao Yang
Nishit Bhosale
Hi Tao Yang,
Thanks for response. There was issue in DNS mapping for WSA host name in DNS Server.
WSA successfully joined domain controller.
I want to know whether Active director agent installation is required for single-sign on.
ADAgent (or now the CDA) is not required for single-sign on/transparent authentication, but it does clear up some issues you'll see with apps that don't support authentication.  For example, Outlook, when there are pics in an HTML mail that have to be downloaded, won't get those pics.  We have a few apps that get licensing over the web that fail.
CDA gets the auth info at login and sends it to the WSA, typically before the user tries to hit the web...
