Cisco WSA CARP and Kerberos Authentication
hkhaida
Hi;
Does Cisco WSA  support  Kerberos Authentication with the vesion AsyncOS 8.7. when it deployed  as cluster of Cisco WSAs in explicit mode using CARP ?
Regards.
Ruben Cocheno
@hkhaida
All sorted?
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
GreenAvice
@hkhaida wrote:
Hi;
Regards.
I faced the same issue, still facing that, no solution yet.
There are some known bugs with special characters in the service account's password
CSCwf37155, CSCvz88197
Or dashes
CSCvt14851
Ticket length issues, especially after recent Windows patches
CSCuo74136
Auth failures in older versions
CSCvh86867
8.x was EOL'd in 2017.. you really should upgrade.
________________________________
This email is intended solely for the use of the individual to whom it is addressed and may contain information that is privileged, confidential or otherwise exempt from disclosure under applicable law. If the reader of this email is not the intended recipient or the employee or agent responsible for delivering the message to the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is strictly prohibited.
If you have received this communication in error, please immediately notify us by telephone and return the original message to us at the listed email address.
Thank You.
