FMC Current Interface Status and Interface traffic Widgets
spauldingd
Frequent Visitor
Frequent Visitor
We have made some changes to our network capacity and are wanting to monitor Interface Status and Traffic.
I have added the Widgets to my dashboard but am only seeing the traffic on ETH0 (management).
The Googles tell me I should be able to add the other interfaces at the widget level.  But the only customization on the widget is frequency of poll.
The Googles also tell me I should be able to make the change at the interface.  But I cannot find any recognizable option.
Suggestions greatly appreciated.
Because you mention that you made changes to your network capacity, I want to ask:
Are you looking to see management traffic to/from the FMC itself on multiple interfaces? (and do you have multiple interfaces connected?)
Or are you looking to see network traffic statistics/load that passes through your firewalls? (in which case you aren't looking at the correct widget)
The "Current Interface Status" and "Interface Traffic" widgets on the FMC only shows traffic to/from the FMC itself (management traffic)
If you want to see the traffic that goes through your firewalls, you can go to system -> health -> monitor and select an individual appliance and go to the interface tab to see traffic.
Please mark helpful answers & solutions
spauldingd
Frequent Visitor
Frequent Visitor
Not as convenient as having it on the main dashboard, but it will suffice.
I am uncertain why I should care how much traffic there is on my management port.  But we take what we can get.
