how to block certain webhosting
Hi all,
i want to block hosting like mediafire.com,maaduu.com etc because using high bandwith.
I already config on custom url categories insert above sample.
i'is ok or Any idea?
5 Replies 5
Chris Illsley
Level 8
Level 8
You can do that, but it's only really useful if there are very specific sites you want to block.
If you are worried about bandwidth there are various other routes you could take:
Stting the "Overall Bandwidth Limits" in Web Security Manager
Going into the Access Policies -> Applications and then you can set  bandwidth limits for Media.
Chris
hi mooncat76,
thanks for reply,
What standard bandiwth limit?
It defaults unlimited.
if cisco best practice?
Best Practice would be to use the built in URL categories and only use custom URL categories when there are specific bespoke groups of URLs you'd need acting on.
For example in this case you may want to bandwidth limit all Media except for something that has a specific business need.
Then you could bandwidth limt Media and "Allow" this custom category to exempt it from other rules.
Chris
