How to block destination port on WSA?
hanguye3
Hi team,
I am working on the policy to control the Viber - which installed on the client laptop. the Viber is using port 4244 for communication.
I want to add the Access Policy on the WSA to block the destination port (4244) but still not find how to configure it.
Highly appreciate for any quick support.
Thanks in advance.
Br,
hainm
Handy Putra
By default WSA does not aware of port 4244 since its only listen to port use by HTTP/HTTPS and FTP.
However in access policy under "Protocol and User Agent" of the policy, there is section called HTTP CONNECT Ports, this is for other ports that WSA can establish HTTP CONNECT to those ports.
As long as port 4244 is not listed there or in that section there is no entry allowing all the ports such as 1-65535, then port 4244 should not be allowed.
Handy Putra
