issue: explicit mode, session cookie surrogate
milanuremovic
Community Member
Hi all,
Consider next scenario:
- deployment mode explicit forward
- proxy port not 80
- authentication surrogate is session cookie
This should work like this:
Client sends request, WSA replies 307 with "Location" header that redirects to itself (WSA) with an internal path which should result in retrieving content if authorized.
Problem occurs in header, "Location" directive, because it does not return configured proxy port, just hostname (eg: Location: http://proxy/internal_path/web_site).
Workaround for this is to configure port 80 as proxy port as well.
Tested on AsyncOS 6.0, 6.3!
David Paschich
Community Member
Minurc, this is a known issue; we're trying to get a fix into a maintenance release for both 6.0 and 6.3. Make sure you have a ticket open with support for this so you'll get notified when the fix is available!
milanuremovic
Community Member
Ok, didn't know that fact. Just came across while testing appliance, and did read known issues for 6.0 and 6.3, but didn't find one explaining it 🙂
But it's good to know that it's in progress. Thanks.
David Paschich
Community Member
Yes, we found the issue too late to include it in the 6.0.1 release notes, unfortunately.
