NTLM Authentication problem join domain
quartino_ironport
Community Member
I want to configure a REALM NTLM.
When I try to join ironport to my Active Directory Domain I get the following error"
"ERROR - Computer Account creation failed
Failure: Error while joining WSA on to server x.x.x.x: Failed to join domain: the network name cannot be found"
I checked on my AD and I notice that the computer object in effect have been created in the right location but it's disabled..??
If I enable and I run the tests, they're successfull but the status is: "Computer account ironport$ not yet created."
In effect If I list the REALM I get "Domain not Joined"
What I'm wrong?
P.S.
If I try to use LDAP it works correctly
jowolfer
Level 7
Level 7
quartino,
I don't know if there is going to be an easy answer on this one. I recommend filing a support ticket. Some further details would be helpful:
1. What version of the WSA are you running?
2. What version of AD are you running? (win2k, 2008, so forth)
