Problem with blocking when uploading documents to Google Drive with the WSA 390
guty_1806
Visitor
Hi:
I'm trying to block the upload of any document to Google Drive. I have applied the configuration in the Applications section within Access Policies, and I have also configured a decryption policy where I define the decrypt rule for the Online Storage and Backup category. But when doing the tests I can still upload files to Google Drive.
I thank you in advance for your collaboration.
Handy Putra
Would recommend to check the accesslogs from WSA when you are trying to upload doc to google drive to check that you are hitting the correct decryption policy and access policy when traffic is successfully decrypted.
Handy Putra
