Quota and Bandwidth Control
diegomartins
You can control the bandwidth per user after reaching a certain limit of Quota?
example:
User may view one hour of videos on the Internet or downloading 100MB of videos.
If you reach your quota this connection is only limited to 200Kbps and not totally blocked.
Does anyone know if it is possible?
stojanr
I don't belive you can set conditional bandwidth limits - you either limit the bandwidth or not.
