Report not working S170
vkragovic
After upgrade to 9.1.1-074 I have problem with Report (by users, Web sites...)
It says "No data was found in the selected time range" but S170 is working normally.
In Alerts this message is:
Counter group "WEB_SERVICES_SUMMARY" does not exist.
An application fault occurred: There was an error opening the database. Reporting cannot continue.
Does anyone have a solution?
Handy Putra
Can you try below:
  1. Enter the CLI and enter commands diagnostic -> reporting
  2. Enter command DISABLE to disable the reporting engine.
  3. Enter command DELETEEXPORTDB.  Note: if there's a lot of backed up data, this command may take a very long time to complete.  If it sits for a long time without making any progress, then the data may need to be removed manually.
  4. Enter command DELETEJOURNALS.
  5. Enter command ENABLE to re-enable the reporting engine.
If its still does not work, recommend to open a TAC case to investigate further.
8 Replies 8
Handy Putra
Can you try below:
Followed these directions and the alert/error remains.
Would recommend to open a TAC case to further investigate the issue, possibly from the back end of the appliance which only TAC engineer has access to it.
I try this and before ENABLE reporting,I enter command DELETEDB and evereything works like before.
Now I have full reporting.
what will be the impact if we execute the commands?
daniel_dantas
Hi :)
The procedure save me.
This procedure solved the problem only for a little time. My s170 stopped the logging freqently after a few days. Any ideas
S170 has a very limited disk and capacity especially with local reporting enabled, this can burden the appliance heavily depending on how busy the appliance is.
When S170 stopped logging frequently, would recommend to open TAC case for the engineer to review the appliance from the backend and check the services and processes and reporting database. From there the engineer can provide you with recommendation or solution.
Handy Putra
