RTMP protocol on port 1935
gabedellaquila
We have a S650, OS 5.6.2-102; a user need to access to a website that has a video streaming that uses protocol RTMP. If i use a pc that do not use proxy, i am able to see it, if i try to access to the same site using the proxy, i get the error "stream not found".
Is there a way i can help this user to see the video?
Gabe
jowolfer
Gabe,
This depends entirely on how your users are getting to the WSA proxy and how your streaming client is configured. Is this RTMP or RTSP? Which client are you using?
It would help to have the access log line that correlates to this traffic, if any.
To grep the access logs for this entry, run the following from the CLI:
1. Grep
2. Enter the number of the log you wish to grep: 1 (for accesslogs)
3. Enter the regular expression to grep: .*
4. Do you want this search to be case insensitive?: Y
5. Do you want to paginate the output?: N
gabedellaquila
The user uses Internet Explore, the video is embedded in a web page and it is an FLV video transported thru rtmp protocol
jowolfer
gabe,
What do the access logs say about this transaction?
