Session resumption setting in WSA
lmoceze
Hey there,
I would like to set up a new WSA, and got the to part of advancedproxyconfig / HTTPS, when it asks me the following:
Do you want to enable session resumption.
[N]>
Where can I check this on my other proxies? I cant seem to find it in the HTTPS proxy settings in GUI, neither in the full showconfig output of another box.
I am probably looking at the wrong place, but Google is also not a help today.
Thanks a lot!
Levente
amojarra
Hello @lmoceze
Thanks for reaching out
Yes, you can not see that from the GUI, in the configuration file, there is a tag:
 session resumption is enabled:
<prox_etc_enable_sess_reuse>1</prox_etc_enable_sess_reuse>
 session resumption is disabled:
<prox_etc_enable_sess_reuse>0</prox_etc_enable_sess_reuse>
before enabling it, kindly review:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwa04247
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvu92674
Amirhossein Mojarrad
++++     If you find this answer helpful, please rate it as such    ++++
lmoceze
And I found that is off by default since ~11.7, but we have some proxies from earlier than that and I am not sure if the previous collegues set it on/off on purpose, or just hit enter to get home earlier.
amojarra
Hello @lmoceze
I told you im looking at the wrong place : D
Thank you very much for your help and mentioning the bugs!
