Web Proxy
dmiller227
Level 2
Level 2
I had Web Proxy and L4 Traffic monitoring going great. Then, after about a day, for no reason, no changes to any configuration on the Ironport or in the infrastructure, the WSA stopped reporting Web Activity. It still reports the L4 Traffic. Can they (Web Proxy and L4) not work at the same time?
Thanks in advance.
jowolfer
Level 7
Level 7
The Proxy and L4TM should work perfectly together. I'm not sure why proxy reporting would stop functioning. Sounds like a good issue for support to look into.
dmiller227
Level 2
Level 2
I figured it out. The customer uses HSRP and it was reeking havoc with the WCCP packets. I finally got it going again.
Hi BigDave,
Could you post what you did to fix this, I have the same issue and would like to know the resolution.
Kind Regards
