Web Reputation Custom Block Notification
eatnoodle
Visitor
Hello all,
Is there an attribute that I can add to our end user notification (EUN) block message that will display the web reputation score of the website?
Thank you,
Jeremy
If you are using "User Defined End User Notification" pages (aka redirecting off the WSA), the attribute is "WBRS", and should already be getting added to the URL you defined as part of a query string so you can get it...
(see the online help:  Contents Tab >> Notifying End Users > Working with User Defined End-User Notification Page)
If you've customized the pages on the box and re-uploaded them, score is %z
(See the online help: Contents Tab >> Notifying End Users > Working With IronPort End-User Notification Pages, theres a section titled "Editing IronPort Notification Pages" about half way down with the info you need)
Ken
Ken
%z worked, thank you.
