WSA ICAP COMMUNICATION USING P1 INTERFACE
Alex2025
Hello Team,
I'm trying to configure an external DLP on WSA. I'm using the ICAP protocol to intercept traffic and send it to the DLP. The traffic is going through the management interface (M1) instead of the production port, even though I've set up specific routes. Is this normal? If not, how can I force ICAP traffic to the production interface?
Hello team,
i solve this point. ICAP use management interface for test and use Prod interface for production traffic.
amojarra
Hello @Alex2025
if you have a separate routing table, lets say:
Management interface: 192.168.1.100/24 : Gateway : 192.168.1.1
P1 interface: 192.168.2.100/24 : Gateway :192.168.2.1
and the DLP server is 192.168.3.33
create an static route in Management routing table for your DLP server, and put the P1's Gateway there
Management Routing table
DLP_Static_Route: 192.168.3.33 -> 192.168.2.1
Amirhossein Mojarrad
++++     If you find this answer helpful, please rate it as such    ++++
Hello team,
