wsa proxy forward and reverse
anishsalamdxbcme
Community Member
       is IronPort wsa capable of Forward and Reverse at the same time
5 Replies 5
I haven't seen any docs on doing that.
I think it could be done... but its not intended to be a reverse proxy...
So means Cisco doesn't any solution for Reverse proxy? hehe
TM13
Level 4
Level 4
Found any solution?
Handy Putra
WSA is only performing forward proxy and does not do reverse proxy (no road map on this yet)
Hi, you can use ASA with Firepower 6 with support for SSL decryption. It's not exactly reverse proxy by design but it can be used as a powerful security solution protecting your infrastructure.
You'll be able to find more info here: http://www.cisco.com/c/en/us/support/docs/security/firesight-management-center/200202-Configuration-of-an-SSL-Inspection-Polic.html
"The main purpose of decrypt known key is to decrypt traffic heading to your https server to protect your servers from external attacks."
