wsa regex issue
Dechamo
Frequent Visitor
Frequent Visitor
With the same regex on WSA, after updating WSA from AsyncOS 15.2.2-009 to AsyncOS 14.5.1-016, the regex that was supposed to block a site no longer blocks it.
someone can help me ?
amojarra
@Dechamo
can you please Share the RegEx, and the URL you were trying to access?
on the other had the order of Custom URL category is important, please make sure there are no other CustomCat above the one that you were expecting to hit,
I would say the best will be to create a test Custom CAT, with your RegEx, put on top , create a test Accesspolicy and Decryption policy for your test PC IP address ( test ID profile) put on top link the Custom cat to your Decryption/Access Policy and test.
if the custom Cat hits, then you need to check which policy it was hitting before these tests policies and trace
Amirhossein Mojarrad
++++     If you find this answer helpful, please rate it as such    ++++
