Webex Teams Window: fix size and location on screen
MartinFrh
Hi, is there a possibility to fix the size and location of the Webex teams window on the screen for the next session? Whenever I open Webex teams new, the window seems to appear in a standard size and location on the screen, but not where it was when I closed Webex teams before.
7 Replies 7
dpell
I just noticed that if I do not use the full screen, that it seems to remember what monitor and what size I want it to show up on.  However, I have not tested this thoroughly.  But I agree it is a bug and it should be fixed.
eric-van-rooij
The way that Webex is handling its windows is completely different from any other application  from a user point of view, and is confusing, and annoying.
My biggest frustration is when working with multiple screens, whetever you move webex main windo to, when you maximize it pops back to the primary sreen. Then wel selecting an other window, it minimizes to a  mini window again that you have to maximize , and guess what... back to the primary screen.
This is really bad.   If you create something for windows platform, follow the Windows development guidelines!
Jeff Dimagmaliw
This is not possible as the position and size of the windows are managed by the OS. You can use a third party solution such as Tasklayout for Windows or Moom for Mac to remember the position and size of the Teams window after each launch.
@Jeff Dimagmaliw
Please allow me to say: This is nonsense / simply not true.
EVERY Windows-application does remember its last window-size and screen (in case there are more than one).
I do not care if this is accomplished by the application or by the operating system - it just works.
Webex-Teams does not behave this way, which is non-standard and unwanted.
The Teams-Client does not even remember my manually adjusted proportions of "contacts-Area" vs. "chat-area" nor does it remember which chat was shown at the last time.
BTW: it´s the same with the Webex-Meetings-Client.
No, I am not going to write a posting at the "User Community Feedback"-Forum regarding this
since this is not "a new feature" but simply a bug.
fix it.
fast.
Thanks.
BTW: No, this request by @MartinFrh is NOT solved, far from that.
Also this wasn't an issue until about a month ago, which points to it being a bug from a recent update.
That does not make since every window in a Mac remembers it's size and location and usually is controlled by the PLIST file.  I am trying to get the Call Window not pop-up in the middle of the screen and remember the size and position I set but every call reverts to the default
