ANURAJ.R
My Cisco AP [AIR-LAP1252G-A-K9]is not booting[not powering on ] after nvram flash.how to fix this problem anybody help me to fix this. This is the commands what i do before AP dead
ap>en
Password:
Password:
ap#dir flash
%Error opening flash:/flash (No such file or directory)
ap#dir flash
*Mar 1 00:08:51.659: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 9c5c.f97e.0dad Reason: Sending station has left the BSS 😕
Directory of flash:/
3 -rwx 76 Mar 1 2002 00:03:13 +00:00 private-multiple-fs.BAK
15 drwx 128 Mar 1 2002 01:13:22 +00:00 c1250-rcvk9w8-mx
4 -rwx 3682 May 11 2020 13:21:32 +00:00 config.txt
5 -rwx 1048 May 11 2020 13:21:32 +00:00 private-multiple-fs
14 -rwx 99952 Mar 1 2002 00:14:42 +00:00 event.log
6 drwx 384 Jan 1 1970 00:19:10 +00:00 c1250-k9w7-mx.124-21a.JY
160 -rwx 437 Mar 1 2002 00:00:09 +00:00 env_vars
161 -rwx 1920 May 11 2020 13:21:32 +00:00 private-config
31868928 bytes total (22405120 bytes free)
ap#
*Mar 1 00:08:55.187: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 9c5c.f97e.0dad Associated KEY_MGMT[WPAv2 PSK]
*Mar 1 00:09:31.255: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 9c5c.f97e.0dad Reason: Sending station has left the BSS
*Mar 1 00:09:37.247: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 9c5c.f97e.0dad Associated KEY_MGMT[WPAv2 PSK]
*Mar 1 00:09:40.371: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 9c5c.f97e.0dad Reason: Sending station has left the BSS
*Mar 1 00:09:45.599: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 9c5c.f97e.0dad Associated KEY_MGMT[WPAv2 PSK]erase
% Incomplete command.
ap#erase ?
/all Erase all files(in NVRAM)
/no-squeeze-reserve-space Do not reserve space for squeeze operation
flash: Filesystem to be erased
nvram: Filesystem to be erased
startup-config Erase contents of configuration memory
ap#erase
*Mar 1 00:10:21.699: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 9c5c.f97e.0dad Reason: Sending station has left the BSS
ap#erase startup-config
*Mar 1 00:10:27.651: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 9c5c.f97e.0dad Associated KEY_MGMT[WPAv2 PSK]
Erasing the nvram filesystem will remove all configuration files! Continue? [confirm]
[OK]
Erase of nvram: complete
ap#
*Mar 1 00:10:31.055: %SYS-7-NV_BLOCK_INIT: Initialized the geometry of nvram
ap#
*Mar 1 00:11:03.743: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 9c5c.f97e.0dad Reason: Sending station has left the BSS reload
Proceed with reload? [confirm]
*Mar 1 00:11:14.967: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 9c5c.f97e.0dad Associated KEY_MGMT[WPAv2 PSK]
*Mar 1 00:11:17.251: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.
Finaly Automaticaly powered off the ap then never Powering on[ALL LED'S ARE OFF]
Dear Legends Pls give me a proper solution to fix this issue.Thanks
ANURAJ.R
i dont understand anything from this link will u pls  tell me the exact solution?
@Leo Laohoo
Scott Fella
What Leo posted is a possible issue with your device that would require replacement if you have a valid support contract.
Erasing the startup config like you did wouldn’t break your AP. Seems like maybe your ap is failing, that is a very old AP.
ANURAJ.R
Ohh my goodness.
i dont have a support contract @Scott Fella  bro..
Rafael E
The field notice share above is the problem you are seeing.
You can try recover the AP from rommon, go to rommon and from there format flash and try to load an image with the code fix for the FN.
If above does not work then you do probably need an RMA
Scott Fella
Yeah… that ap is end of support, so basically it's a paper weight at this point.
https://www.cisco.com/c/en/us/obsolete/wireless/cisco-aironet-1250-series.html
rafafilho11
We'll need to RMA the device, it's a Hardware issue
These product symptoms are observed:
  • The AP does not boot
  • The AP's LEDs are all red
  • The AP does not respond on its console
Workaround/Solution
Normal SmartNet and warranty entitlement rules remain in place and are applied by the Cisco Technical Assistance Center (TAC) if you experience a failure in one of the products listed in the Field Notice. In other circumstances, such as out of warranty or out of contract, Cisco encourages you to raise your concern directly with your Cisco account team.
Fix on Failure Replacement Guidelines: Request Return Material Authorization (RMA) product through normal service support channels.
If you need assistance in order to determine which hardware part(s) might need replacement, consult the error messages documented in the Problem Symptom section.
https://www.cisco.com/c/en/us/support/docs/field-notices/637/fn63763.html
