remi_at
Symptoms
You want to automate guest-user creation on your Cisco 9800 Wireless LAN Controller
Solution
Since new WLCs do not allow adding guest users via SNMP, I have created a new script that uses RESTCONF via HTTPS.
Tested on Cisco 9800-CL virtual wireless controller 17.3
You can find the script here:
public-scripts/New-GuestUserREST at main · automate-this/public-scripts (github.com)
