TCC_2
Level 10
Level 10
Introduction
How to troubleshoot LEDs on a wireless bridge
Resolution
If your wireless bridge is not communicating, check the three LED indicators on the top panel. You can use them to assess the unit's status quickly.
For information on understanding LEDs on the wireless bridge, refer to the following documents:
If your bridge is not associating with the remote bridge, check the four LEDs on the back panel. You can use them to quickly assess the unit's status. For information on using the LEDs during the installation and alignment of the bridge antenna, refer to the "Bridge LEDs" section in the Cisco Aironet 1400 Series Wireless Bridge Hardware Installation Guide. Click this link to browse to the Hardware Installation Guide:
http://www.cisco.com/en/US/docs/wireless/bridge/1400/installation/guide/1400hig4.html
1400 Series Bridge:
Ethernet LED
Radio LED
Status LED
Install LED
Table 19-2     Bridge LED Blinking Error Codes
LED
Blinking Codes
Description
First
Digit
Second Digit
Ethernet
Ethernet cable problem—verify that the cable is properly connected and not defective. This error might also indicate a problem with the Ethernet link. If the cable is connected properly and not defective, contact technical support for assistance.
Radio
Radio not detected—contact technical support for assistance.
Radio not ready—contact technical support for assistance.
Radio did not start—contact technical support for assistance.
Radio failure—contact technical support for assistance.
Radio did not flash its firmware—contact technical support for assistance.
1300 Series wireless outdoor Access Point/ Bridge:
If your access point/bridge is not associating with a remote bridge or access point, check the four LEDs on the back panel. You can use them to quickly assess the unit's status. For information on using the LEDs during the installation and alignment of the access point/bridge antenna, refer to the Cisco Aironet 1300 Series Outdoor Access Point/Bridge Mounting Instructions that shipped with your access point/bridge.
R
Radio LED
E
Ethernet LED
S
Status LED
I
Install LED
Problem Type
LEDs
How to...
Products
Bridge
Reference
1400 Series Bridge: Checking the Bridge LEDs
1300 Series wireless outdoor Access Point/ Bridge:Checking the LEDs
