TCC_2
Level 10
Level 10
Introduction
Is it possible to log authentication requests from an Access Point to the syslog server?
Resolution
By default, Access Points (APs) send the output from system messages and debug privileged EXEC commands to a logging process. The logging process controls the distribution of logging messages to various destinations, such as the logging buffer, terminal lines, or a UNIX syslog server, depending on your configuration. The process also sends messages to the console.
Defining the Message Severity Level
You can limit messages displayed to the selected device by specifying the severity level of the message, which are described in Table.
Beginning in privileged EXEC mode, follow these steps to define the message severity level:
Command
Purpose
Step 1
configure terminal
Enter global configuration mode.
Step 2
logging console level
Limit messages logged to the console. By default, the console receives debugging messages and numerically lower levels.
Step 3
logging monitor level
Limit messages logged to the terminal lines. By default, the terminal receives debugging messages and numerically lower levels.
Step 4
logging trap level
Limit messages logged to the syslog servers.By default, syslog servers receive informational messages and numerically lower levels. For complete syslog server configuration steps, see the "Configuring UNIX Syslog Servers" section.
Step 5
end
Return to privileged EXEC mode.
Step 6
show running-config
or
show logging
Verify your entries.
Step 7
copy running-config startup-config
(Optional) Save your entries in the configuration file.
Note
Specifying a level causes messages at that level and numerically lower levels to be displayed at the destination.
To disable logging to the console, use the no logging console global configuration command. To disable logging to a terminal other than the console, use the no logging monitorglobal configuration command. To disable logging to syslog servers, use the no logging trap global configuration command.
Table describes the level keywords. It also lists the corresponding UNIX syslog definitions from the most severe level to the least severe level.
Message Logging Level Keywords
Level Keyword
Level
Description
Syslog Definition
emergencies
System unstable
LOG_EMERG
alerts
Immediate action needed
LOG_ALERT
critical
Critical conditions
LOG_CRIT
errors
Error conditions
LOG_ERR
warnings
Warning conditions
LOG_WARNING
notifications
Normal but significant condition
LOG_NOTICE
informational
6
Informational messages only
LOG_INFO
debugging
7
Debugging messages
LOG_DEBUG
The software generates four other categories of messages:
Error messages about software or hardware malfunctions, displayed at levels warnings through emergencies. These types of messages mean that the functionality of the access point is affected.
Output from the debug commands, displayed at the debugging level. Debug commands are typically used only by the Technical Assistance Center (TAC).
Interface up or down transitions and system restart messages, displayed at the notifications level. This message is only for information; access point functionality is not affected.
Reload requests and low-process stack messages, displayed at the informational level. This message is only for information; access point functionality is not affected.
Note
Authentication request log messages are not logged on to a syslog server. This feature is not supported on Cisco Aironet access points.
Problem Type
Release notes / product  overview / data sheet / FAQ
Products
Access point
Reference
Understanding System Message Logging
