02-21-2014 04:14 AM - edited 11-18-2020 03:06 AM
7.6.110.0 posted in CCO.
For any new issue during this test, please write to wnbu-mrbeta@external.cisco.com, pre-existing problems would be directed through normal TAC support channels, the image is TAC supported until CCO release of final code
AS_5500* can be used for Wism2/2500/5500 controller types
AS_7500* can be used for 7500/8500
AS_CTVM can be used for vWLC
CSCun37799 VideoStream fails with 7.6 on WPA2 SSID
CSCum68243 Corfu: dot11 ant-band-mode command is missing in autonomous image
CSCuj17283 ap3700 uses 8 replay counters w/ clients that support only 1 (ARP fails)
CSCum16566 Corfu SKU-C :- fix ETSI domain 2.4Ghz radio config for 802.3at power
CSCum53468 DNS resolver enabled on AP
CSCum17989 After DFS RM3000AC-Q and AP3702I-Q show illegal channel 144 in CBW80 use
CSCum49200 7.6: Broadcom client connectivity problems if WMM enabled w/ ap3600
CSCun02785 Corfu:- 7.6 D-domain 5G CTL update
CSCun28873 OEAP600 cannot connect to WLC running 7.6.101.7 -> Junked (invalid bug)
Image types
AS_4200* can be used for 4400/wism1
WiSM-1 and 4400??? Really?
thanks for reporting, copy&paste error, corrected 🙂
regards
Thanks for posting the update- but is there any better sense of timing for when the fully-baked download will be ready? Some of us have 3700s stacked up waiting to install, and can't afford to do two code updates within a couple of weeks of each other.
Current timeframe for release is mid-March
regards
When is the official release of 7.6MR 1?
Is CSCuh72474 going to be addressed in this release?
Hola Javier!!!
7.6.110.0 seems to be availible for download. Any release notes? I can't find any info.
Cheers
Anders
Hi David
Bug:
CSCuh72474 Interface inside a group gets Dirty due to DHCP flood by client and NAK
is not included in 7.6.110.0, we plan to include in next manteniance release (7.6MR2)
regards
hi
Final image is now posted
regards
Hi Javier,
I have a question regarding to what version to choose when upgrading our system.
We currently are running PI 2.0, with WiSM2 (7.2.110.0) and MSE 3350 (7.2.110.0).
We are getting new equipment shortly, with new MSE 3355 to replace the old 3350 and a few mesh AP1552EU. By reading the lastest release notes of the 7.6.110.0, I noted that AIR-CAP1552EU-x-K9 is first supported from 7.5.102.0. However, in table 4 Solution Compatibility Matrix, it recommended 7.4 (MD train) for PI 2.0, and 7.6 for MSE. If this is true, Can I still deploy the AIR-CAP1552EU-x-K9 and make full use of it? Or what is latest/best version we should upgrade to support new MSE 3355, new 1552EU and working with PI 2.0 properly?
Please advise. Thanks very much for your time in advance.
Joey
