Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Hi Team Kindly help me to build the automation for Meraki device (MX/MS/MR) through Cisco Automation - Schedule Firmware Upgrade for Networks by TagI am looking for Step by Step process so that I can test for my LAB environment.
Over the past few months, I've been working on a project that aims to simplify one of the most repetitive and important tasks in network administration: reviewing the security configuration of Cisco router and switch interfaces.Today, I'm excited to...
Hi I've been testing some script againts ISE 3.2.0 OpenAPI to test the functionality and i found an issue in uploading a trusted certificate for Letsencrypt via the openapi. If i download the intermediate certificate from https://letsencrypt.org/cert...
Hi all, I used Gemini to help me write the following PowerShell script to pull custom events down from Secure Network Analytics, but when I run the script, I get the "The script connected and authenticated successfully, but the API returned 0 events....
Cisco ISE Guest User Bulk Creation with Python and the ERS APIManaging guest accounts in Cisco Identity Services Engine (ISE) is a common operational task for network engineers. Whether onboarding a handful of contractors or provisioning hundreds of ...
Currently, I might go through several different versions of a workflow or atomic. Is there a best practice or a way to do versioning? Since there is no undo button for removing elements, I have become much more judgmental about how to implement certa...
As part of an initial incident response, I would like to run a full scan from a secure endpoint. Although I searched, I do not see this in the API documentation showing this as an option at the moment.Is there a different way to approach this, or is ...
Automation Rules can target many things, but I would like to use detections as targets rather than incidents, as not all detections are raised to incidents. From the detection alone, there might be certain actions I would like to take. If detections ...
Hi,we need to fetch a list of all sgmappinggroup present in ISE (Cisco ISE 3.2 Patch 9). According to the documentation (https://developer.cisco.com/docs/identity-services-engine/v1/ers-open-api-ers-open-api/), the following request should return a l...
We run FTDv HA pair managed by FMC on a 4-node vSAN cluster. Started noticing that VMs on the node where active FTD resides cannot establish TCP sessions (HTTPS, RDP) to resources in the same VLAN, while ICMP works fine. Moving VM to another node fix...
Could you please provide information on the Umbrella API?I have reviewed the site below, and my understanding is that it is possible to add identities to existing policies and to create the Destination Lists and Application Lists used by policies.Is ...
Overview Certificate-based authentication provides a more secure method for API clients to authenticate without transmitting passwords. Certificate-based authentication for API calls was introduced in Cisco ISE Release 3.3 as a new feature. This guid...
Hello TeamWhen I doing POST(PowerShell), SMC returns an error:{ "errors" : [ { "code" : 5060, "message" : "The Request received is invalid" }, "Invalid JSON." ] }This is a part of PowerShell script I use: # JSON query body $body = '{ "startDateTime":...
