cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
8
Respuestas
AP mode Autonomous
ekeas-2012
Community Member
Hi everybody, I have a real problem, I tell you, I need configure an AP
cisco air ap1261n-a-k9 on mode Autonomous
Someone who helpme !?!?!?!?!
TNX
8 RESPUESTAS 8
ekeas-2012
Community Member
aaaaaaaaaaaaaaaayyyyyyyyyyyyyyyyyyyyyyyyuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuudddddddddddddddddddddddddddddddddaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
Well I share with you the solution that worked with my devices
do sh run
Building configuration...
Current configuration : 1861 bytes
version 12.4
no service pad
service password-encryption
hostname casa2
logging rate-limit console 9
enable secret 5 $1$oLCJ$yT7nlIKB7toRhBSz3oqUN0
no aaa new-model
ip dhcp excluded-address 192.168.1.1 192.168.1.73
dot11 syslog
dot11 vlan-name internet vlan 2
dot11 vlan-name red_lan vlan 1
dot11 ssid sala
   vlan 1
   authentication open
   authentication key-management wpa
   guest-mode
   mbssid guest-mode
   infrastructure-ssid optional
   wpa-psk ascii 7 095C4F1A0A1218000F
username Cisco password 7 032752180500
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers tkip
encryption vlan 2 mode ciphers tkip
ssid sala
antenna gain 0
mbssid
channel 2462
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address 192.168.1.73 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 protocol ieee
bridge 1 route ip
line con 0
line vty 0 4
login local
end
Hola Aron,
Me podrias brindar mas informacion sobre el problema que tienes con la configuracion de tu AP?
Que necesitas configurar? que no te esta funcionando?
Dame todos los detalles que puedas y con mucho gusto te ayudare.
Saludos,
Angel Vargas
Cisco TAC Wireless Engineer
Que tal Angel,
Pues el problema quedo resuelto con la cofig que deje, pues el problema radicaba en como pasar una red hacia el ap, pero no tenia idea de como le tenia que hacer ademas que era muy urgente, por eso necesitaba una ayuda practicamente de un dia para otro pero ya quedo pero te agradezco el interes y bueno una ultima pregunta, Notas algo raro en la configuracion que deje??
Buen dia y muchas gracias...
Hola Aron,
Gracias por la informacion.
Lo unico que note en tu configuracion es lo siguiente:
en el SSID tienes:
guest-mode
mbssid guest-mode
Solo necesitas 1 de esos comandos:
guest-mode si solo vas a hacer broadcast de 1 solo SSID.
Mbssid guest-mode si vas a hacer broadcast de mas de 1 SSID ( cada SSID debe llevar este comando)
Note: el commando mbssid debe estar en el radio para poder hacer broadcast de mas de 1 SSID
este comando no es necesario si solo vas a conectar clientes wireless.
TKIP es un method de encripcion un poco viejo (WPA1) Te recomiendo usar AES-CCM que es WPA2.
encryption vlan 1 mode ciphers aes
encryption vlan 2 mode ciphers aes
No veo ningun otro problema con al configuracion.
Espero esto te ayude.
Ten un muy buen dia.
Saludos,
Angel V.
Muchas gracias Angel, es informacion muy valiosa me sirvio mucho para depurar
Buen dia...
Con todo gusto Aron.
Cualquier otra duda, aqui estamos para ayudarte.
Saludos,
Angel V.
Abhishek Abhishek
Hello Aron,
As per your query i can suggest you the following solution-
Using a Controller to Return the Access Point to Autonomous Mode
Follow these steps to return a lightweight access point to autonomous mode using a controller:
Step 1 Log into the CLI on the controller to which the access point is associated and enter this command:
config ap tftp-downgrade tftp-server-ip-address filename access-point-name
(where:
a) tftp-server-ip-address is the IP address of the TFTP server
b) filename is the full path and filename of the access point image file, such as
D:/Images/c1200-k9w7-tar.123-8.JA.tar
c) access-point-name is the name that identifies the access point on the
gondolier.)
Step 2 Wait until the access point completes the reboot, as indicated by the Status LED turning green to indicate a client is associated or blinking green to indicate a client is not associated.
Step 3 After the access point reboots, reconfigure it using the access point GUI or the CLI.
Hope this will help you.
