cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
cisco AIR-AP1041N-A-K9
jos.neira
hola, hace poco configure unos ap cisco y tengo problemas por que pierdo conexion con los equipos y tengo k desconectarme y volver a conectarme, ademas hay unas ipresoras wiffi y no puedo imprimir en red por que pierden la coneccion les adjunto la configuracion para ver si me pueden ayudar
saludos gracias
Current configuration : 1740 bytes
version 12.4
no service pad
service password-encryption
hostname DAS_Piso1
logging rate-limit console 9
enable secret 5 $1$oER/$7nwAzFB.d5Et7./DVsGCl0
no aaa new-model
ip name-server 200.54.0.10
no ip dhcp use vrf connected
ip dhcp excluded-address 90.0.10.1 90.0.10.210
ip dhcp excluded-address 90.0.10.230 90.0.10.255
ip dhcp excluded-address 90.0.10.224
ip dhcp pool 1
ip dhcp pool DAS
   network 90.0.10.0 255.255.255.0
   dns-server 200.54.0.10
   default-router 90.0.10.3
   lease 0 1
dot11 syslog
dot11 ssid DAS_Piso1
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 7 09484F1A4857424413
username Admin password 7 130816001D05172F39
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid DAS_Piso1
antenna gain 0
channel 2412
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface GigabitEthernet0
no ip address
ip accounting output-packets
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address 90.0.10.200 255.255.255.0
no ip route-cache
ip default-gateway 90.0.10.3
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
password 7 011E07164D02150A33
login
line vty 0 4
password 7 0702205E58000A0005
login
end
0 RESPUESTAS 0
