cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Wireless signal problem
Charles Rayer
Level 2
Level 2
So, I have a site in a heavily congested wireless area - up to 40 different signals at the same time. So we are using A signals. There is an entrance where the car jockeys stand - they use a 7921 mobile and are constantly having signal issues.
We tried them on a 7925 but the signal was worse.
We had a 1242 in the reception area, and another one as close to the outside area as possible - however it still didn't fix the problem. So we upgraded the AP in reception to a 1262, but the drivers still complain about losing signal.
I think the metalwork around the doorway kills the signal from the 1262 - there are massive interruptions in service as you walk through the doorway. Also I believe they've used some sort of metallic paint on the inside of the building.
Short of giving up I'd like to try one more thing.
Is there such a thing as an external aerial that I can fit to the outside of the building? There is a fancy box which displays a menu and it's a perfect position to fit a thin aerial inside.
Can anyone recommend me a product for this please?
0 RESPUESTAS 0
