cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Wifi intermittent - C9800-CL Wireless Controller
Electronic20
There is a problem with a 5-second drop in Wi-Fi randomly at any time, the strange thing is that it does not happen equally to all, one client may be fine but the other has a 5-second drop.
I have this image as an example of its client parameters:
What would be the optimal thresholds or between what values should the following parameters be, according to the image, so that the client does not have Wi-Fi drop problems:
Number of Policy Errors
Radio Signal Strength Indicator
Signal to Noise Ratio
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
 You may hear different values from others engineers but I consider SNR between 15 up to 35  and RSSI between -60 up to -75 as good condition.
 I will take a look on this version and see if there are some known but with similar behavior. .
Ver la solución en mensaje original publicado
10 RESPUESTAS 10
 What I can say is that the signal for this client on that moment was excellent.  -64dBm RSSI and most important 34 dB SNR is probably the best condition a client might have.
 Whatever is the problem, for sure it is not related to the signal on that moment.
Share the WLC version, this can be a bug, for example. And look the logs, they can show you something.
thank you,
This is the device and the firmware version:
Cisco Catalyst 9800-CL Wireless Controller
17.6.4
Regarding the thresholds, what would they be? Up to what value is allowed for the condition of an optimal, regular and bad Wi-Fi signal?
Thank you very much, I await your comment
Sure. If there are any  logs you may see to share, would be great.
I have this capture, regards
ammahend
what is your DCA run interval ?
-hope this helps-
from one hour
can you share some more client details
sh wireless stats client detail | e : 0
show wireless stats client delete reasons | ex _:_0
show wireless stats trace-on-failure | ex : 0
-hope this helps-
Electronic20
The problem was solved, it was a matter of the customer's switch network.
thanks for the support provided.
