I'm trying to get the equivalent of "show ip mroute" with RESTCONF on catalyst 9500 with ios-xe version 16.12.3a.
I checked several Yang modules, but it seems the only ones to have these information are MIB modules, like Cisco-IPMROUTE-MIB.
I didn’t succeeded in making it work.
With snmpwalk, it works fine : snmpwalk -v 3 -u username -a SHA -A userpwd -x AES -X pwd2 -l authPriv 10.1.1.1 1.3.6.1.2.1.83.1.1.1 gave an the answer (the number of mroute on the switch).
But I didn’t find how to add username, userpwd and pwd2 in https request!
I tried: https://username:userpwd@10.1.1.1/restconf/data/CISCO-IPMROUTE-MIB/ciscoIpMRoute/ciscoIpMRouteNumberOfEntries
But I don’t know how to give “pwd2”…
Any ideas ?
Thanks.
Solved! Go to Solution.
Hello Noel,
I setup a quick lab with a C9500-40X and version 16.12.3a:
LAB_Switch# show version | begin Switch Ports Model
Switch Ports Model SW Version SW Image Mode
* 1 50 C9500-40X 16.12.3a CAT9K_IOSXE BUNDLE
In order to be able to retrieve SNMP MIBS from RESTCONF/NETCONF we need to add specific configuration to the device:
username cisco privilege 15 password 0 cisco
ip http server
ip http authentication local
ip http secure-server
snmp-server community cisco RW
netconf-yang
netconf-yang cisco-ia snmp-community-string cisco
restconf
Is important to include the command netconf-yang cisco-ia snmp-community-string <string> with the same string that is applied with the snmp-server community <community> <RW | RO> configuration.
I setup only 1 multicast route entry in the box, but this is enough for the test:
LAB_Switch# show ip mroute summary
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
L - Local, P - Pruned, R - RP-bit set, F - Register flag,
T - SPT-bit set, J - Join SPT, M - MSDP created entry, E - Extranet,
X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
U - URD, I - Received Source Specific Host Report,
Z - Multicast Tunnel, z - MDT-data group sender,
Y - Joined MDT-data group, y - Sending to MDT-data group,
G - Received BGP C-Mroute, g - Sent BGP C-Mroute,
N - Received BGP Shared-Tree Prune, n - BGP C-Mroute suppressed,
Q - Received BGP S-A Route, q - Sent BGP S-A Route,
V - RD & Vector, v - Vector, p - PIM Joins on route,
x - VxLAN group, c - PFP-SA cache created entry,
* - determined by Assert
Outgoing interface flags: H - Hardware switched, A - Assert winner, p - PIM Join
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 224.0.1.40), 03:19:34/00:02:07, RP 0.0.0.0, OIF count: 2, flags: DCL
LAB_Switch# show ip mroute count terse
IP Multicast Statistics
1 routes using 1384 bytes of memory
1 groups, 0.00 average sources per group
To retrieve this information with SNMP run the command snmpwalk -v <version> -c <community> <host> 1.3.6.1.4.1.9.10.2, the result is:
MacOS_Catalina_10.15.7$ snmpwalk -v 2c -c cisco 10.62.149.55 1.3.6.1.4.1.9.10.2
SNMPv2-SMI::enterprises.9.10.2.1.1.1.0 = Gauge32: 1
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.12.224.0.1.40.0.0.0.0.255.255.255.255 = INTEGER: 2
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.13.224.0.1.40.0.0.0.0.255.255.255.255 = INTEGER: 2
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.14.224.0.1.40.0.0.0.0.255.255.255.255 = INTEGER: 1
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.15.224.0.1.40.0.0.0.0.255.255.255.255 = INTEGER: 1
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.16.224.0.1.40.0.0.0.0.255.255.255.255 = INTEGER: 2
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.17.224.0.1.40.0.0.0.0.255.255.255.255 = INTEGER: 2
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.18.224.0.1.40.0.0.0.0.255.255.255.255 = INTEGER: 2
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.19.224.0.1.40.0.0.0.0.255.255.255.255 = Gauge32: 0
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.20.224.0.1.40.0.0.0.0.255.255.255.255 = INTEGER: -1
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.21.224.0.1.40.0.0.0.0.255.255.255.255 = INTEGER: 2147483647
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.22.224.0.1.40.0.0.0.0.255.255.255.255 = INTEGER: -1
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.23.224.0.1.40.0.0.0.0.255.255.255.255 = Timeticks: (26513740) 3 days, 1:38:57.40
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.24.224.0.1.40.0.0.0.0.255.255.255.255 = Gauge32: 4294967295
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.25.224.0.1.40.0.0.0.0.255.255.255.255 = INTEGER: 1
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.26.224.0.1.40.0.0.0.0.255.255.255.255 = INTEGER: 2
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.27.224.0.1.40.0.0.0.0.255.255.255.255 = INTEGER: 2
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.28.224.0.1.40.0.0.0.0.255.255.255.255 = Counter64: 0
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.30.224.0.1.40.0.0.0.0.255.255.255.255 = Counter64: 0
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.31.224.0.1.40.0.0.0.0.255.255.255.255 = Counter64: 0
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.32.224.0.1.40.0.0.0.0.255.255.255.255 = Gauge32: 4294967295
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.33.224.0.1.40.0.0.0.0.255.255.255.255 = INTEGER: 1
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.34.224.0.1.40.0.0.0.0.255.255.255.255 = INTEGER: 2
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.35.224.0.1.40.0.0.0.0.255.255.255.255 = INTEGER: 2
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.36.224.0.1.40.0.0.0.0.255.255.255.255 = INTEGER: 2
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.37.224.0.1.40.0.0.0.0.255.255.255.255 = INTEGER: 2
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.38.224.0.1.40.0.0.0.0.255.255.255.255 = INTEGER: 2
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.39.224.0.1.40.0.0.0.0.255.255.255.255 = INTEGER: 2
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.40.224.0.1.40.0.0.0.0.255.255.255.255 = INTEGER: 2
SNMPv2-SMI::enterprises.9.10.2.1.1.2.1.41.224.0.1.40.0.0.0.0.255.255.255.255 = INTEGER: 2
SNMPv2-SMI::enterprises.9.10.2.1.1.3.1.9.224.0.1.40.0.0.0.0.255.255.255.255.13.224.0.1.40 = Gauge32: 4294967295
SNMPv2-SMI::enterprises.9.10.2.1.1.3.1.9.224.0.1.40.0.0.0.0.255.255.255.255.45.224.0.1.40 = Gauge32: 4294967295
SNMPv2-SMI::enterprises.9.10.2.1.1.3.1.10.224.0.1.40.0.0.0.0.255.255.255.255.13.224.0.1.40 = ""
SNMPv2-SMI::enterprises.9.10.2.1.1.3.1.10.224.0.1.40.0.0.0.0.255.255.255.255.45.224.0.1.40 = ""
SNMPv2-SMI::enterprises.9.10.2.1.1.3.1.11.224.0.1.40.0.0.0.0.255.255.255.255.13.224.0.1.40 = Counter64: 0
SNMPv2-SMI::enterprises.9.10.2.1.1.3.1.11.224.0.1.40.0.0.0.0.255.255.255.255.45.224.0.1.40 = Counter64: 0
SNMPv2-SMI::enterprises.9.10.2.1.1.5.1.1.13 = Counter64: 0
SNMPv2-SMI::enterprises.9.10.2.1.1.5.1.1.45 = Counter64: 0
SNMPv2-SMI::enterprises.9.10.2.1.1.5.1.2.13 = Counter64: 0
SNMPv2-SMI::enterprises.9.10.2.1.1.5.1.2.45 = Counter64: 0
SNMPv2-SMI::enterprises.9.10.2.1.1.5.1.3.13 = Counter32: 0
SNMPv2-SMI::enterprises.9.10.2.1.1.5.1.3.45 = Counter32: 0
SNMPv2-SMI::enterprises.9.10.2.1.1.5.1.4.13 = Counter64: 0
SNMPv2-SMI::enterprises.9.10.2.1.1.5.1.4.45 = Counter64: 0
SNMPv2-SMI::enterprises.9.10.2.1.1.5.1.5.13 = Counter32: 0
SNMPv2-SMI::enterprises.9.10.2.1.1.5.1.5.45 = Counter32: 0
SNMPv2-SMI::enterprises.9.10.2.1.1.5.1.6.13 = Counter64: 0
SNMPv2-SMI::enterprises.9.10.2.1.1.5.1.6.45 = Counter64: 0
To retrieve the MIB from RESTCONF in JSON format run:
curl -k -u cisco:cisco -H "Accept: application/yang-data+json" https://10.62.149.55:443/restconf/data/CISCO-IPMROUTE-MIB
"CISCO-IPMROUTE-MIB:CISCO-IPMROUTE-MIB": {
"ciscoIpMRoute": {
"ciscoIpMRouteNumberOfEntries": 1
To filter the result and change the output to XML run:
curl -k -u cisco:cisco -H "Accept: application/yang-data+xml" https://10.62.149.55:443/restconf/data/CISCO-IPMROUTE-MIB:CISCO-IPMROUTE-MIB/ciscoIpMRoute/ciscoIpMRouteNumberOfEntries
<ciscoIpMRouteNumberOfEntries xmlns="urn:ietf:params:xml:ns:yang:smiv2:CISCO-IPMROUTE-MIB" xmlns:CISCO-IPMROUTE-MIB="urn:ietf:params:xml:ns:yang:smiv2:CISCO-IPMROUTE-MIB">1</ciscoIpMRouteNumberOfEntries>
The difference with RESTCONF and SNMP is due to the YANG model:
https://github.com/YangModels/yang/blob/master/vendor/cisco/xe/16121/MIBS/CISCO-IPMROUTE-MIB.yang
This model provides the number of entries in the IPMROUTE through OID 1.3.6.1.4.1.9.10.2.1.1.1 with the container ciscoIpMRoute:
container CISCO-IPMROUTE-MIB {
config false;
container ciscoIpMRoute {
smiv2:oid "1.3.6.1.4.1.9.10.2.1.1";
leaf ciscoIpMRouteNumberOfEntries {
type yang:gauge32;
description
"Maintains a count of the number of entries in the
ipMRouteTable.";
smiv2:max-access "read-only";
smiv2:oid "1.3.6.1.4.1.9.10.2.1.1.1";
Hi Noel
With SSL connectivity you don't need 'pwd2'. The SSL connection authentication is going over server CA certificate verification. In order to make it work from YDK or using curl utility, you need to obtain server CA certificate from your device and then install it on your application platform. The YDK-0.8.5 offers some guidance on this subject; please check it here.
Also. In the command line (and YDK) you have to specify port number, where Restconf is listening. For example:
curl https://username:userpwd@10.1.1.1:443/restconf/data/CISCO-IPMROUTE-MIB/ciscoIpMRoute/ciscoIpMRouteNumberOfEntries
curl --location --request GET 'https://10.200.44.1/restconf/data/ietf-routing:routing' --header 'Accept: application/yang-data+json' --header 'Authorization: Basic XX'The pwd2 is the password for SNMP packets AES encryption, and I don't know where to write it.
Hello Noel,
ip http server
netconf-yang
restconf
"ciscoIpMRoute": {
config false;
type yang:gauge32;
description
ipMRouteTable.";
Hello David,
thanks for your reply.
My configuration is SNMPv3 only, so I have no community configured.
I will had one and test this solution.
Does that mean that it is not possible to make it work with SNMP v3 ?
I haded a community, and it works fine !
Thanks !
