返信
Cisco891でRAS受け口設定
適用対象外
Cisco891のINSでRAS受け口の設定としていますが、2B目接続時に1B目の通信が断となります。
先に接続しPPP振り出したIPと、あとから接続したPPP振り出しIPが同じアドレスとなり
先に接続されていた通信が断となった。
設定は下記で、一つのDialerインタフェースとしているのですが、一つでは同時に2B
受けられないのでしょうか。
interface Dialer0
 ip unnumbered GigabitEthernet8
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 peer default ip address pool pool1
 ppp authentication chap
ip local pool pool1 192.168.206.90 192.168.206.91
1B目接続ログ
*May 17 14:28:09: BR0:1 IPCP: State is Open
*May 17 14:28:09: Di0 Added to neighbor route AVL tree: topoid 0, address 192.16
8.206.90
*May 17 14:28:09: Di0 IPCP: Install route to 192.168.206.90
2B目接続
*May 17 14:29:10:  Invoked enable BRI channel
*May 17 14:29:10: %DIALER-6-BIND: Interface BR0:2 bound to profile Di0
*May 17 14:29:10: BR0:2 PPP: Sending cstate UP notification
*May 17 14:29:10: BR0:2 PPP: Processing CstateUp message
*May 17 14:29:10: PPP: Alloc Context [ED8B55C]
*May 17 14:29:11: BR0:2 IPCP AUTHOR: Start.  Her address 0.0.0.0, we want 192.16
8.206.90
*May 17 14:29:11: BR0:2 IPCP AUTHOR: Done.  Her address 0.0.0.0, we want 192.168
.206.90
*May 17 14:29:11: BR0:2 IPCP: State is Open
*May 17 14:29:11: Di0 Unable to add neighbor route to AVL tree:topoid 0, address
 192.168.206.90
*May 17 14:29:11: Di0 IPCP: Route not installed to 192.168.206.90
*May 17 14:30:13: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0:2, change
d state to down
*May 17 14:30:13: BR0:2 PPP: Phase is DOWN
*May 17 14:30:30: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0:1, change
d state to down
*May 17 14:30:30: BR0:1 PPP: Sending cstate DOWN notification
*May 17 14:30:30: %DIALER-6-UNBIND: Interface BR0:1 unbound from profile Di0
*May 17 14:30:30: Di0 Deleted neighbor route from AVL tree: topoid 0, address 19
2.168.206.90
*May 17 14:30:30: Di0 IPCP: Remove route to 192.168.206.90
0件の返信0
