取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
各位老铁,Catalyst Cisco C6807-XL的ios镜像可以跨版本升级吗?跨版本升级之后是不是解决没升级之前的某些漏洞呢?
349797592@qq.com
目前我们这边思科型号为Catalyst Cisco C6807-XL交换机系统引导程序版本为 5.3(04r)SYS , 引导程序文件为s6t64-adventerprisek9_npe-mz.SPA.155-1.SY7.bin ,如下show version所示.
目前准备对该设备进行系统引导程序的升级,目前通过官网https://software.cisco.com/download/home/286305096/type/280805680/release/15.5.1-SY10  可以查询到官网推荐的引导程序的版本为 15.5.1-SY10(MD),该版本是不是有解决没升级前 5.3(04r)SYS 版本的漏洞问题呢?谢谢各位老铁回答!
HQ-CAS-28F-CSW-01#show version
Cisco IOS Software, s6t64 Software (s6t64-ADVENTERPRISEK9_NPE-M), Version 15.5(1)SY7, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Tue 09-Mar-21 11:21 by prod_rel_team
ROM: System Bootstrap, Version 15.3(04r)SYS, RELEASE SOFTWARE
HQ-CAS-28F-CSW-01 uptime is 44 weeks, 2 days, 15 hours, 13 minutes
Uptime for this control processor is 44 weeks, 2 days, 15 hours, 14 minutes
System image file is "bootdisk:/s6t64-adventerprisek9_npe-mz.SPA.155-1.SY7.bin"
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco C6807-XL ( Intel(R) Core(TM) i3-3227U CPU @ 2.50GHz ) processor (revision ) with 2879482K/524288K bytes of memory.
Processor board ID FGE20501EE2
Processor signature 0xA9060300
Last reset from power-on
36 Virtual Ethernet interfaces
193 Gigabit Ethernet interfaces
16 Ten Gigabit Ethernet interfaces
4 Forty Gigabit Ethernet interfaces
3833840K bytes of USB Flash bootdisk (Read/Write)
2 个已接受解答
已接受的解答
15.5(1)SY10解决的bug如下:
Caveats in Release 15.5(1)SY10
Caveats Open in Release 15.5(1)SY10
None.
Caveats Resolved in Release 15.5(1)SY10
Identifier
Component
Description
CSCwb12806
cat6000-ipc
Crash on Cat6800 sup 2T while processing incoming DHCP packet with ip helper-address as source
CSCwc49173
cat6000-l2
SCP messages takes time when CTS sessions are closed during LC reset
其他版本解决的bug,也可以参考对应的release note。
Release Notes for Cisco IOS Release 15.5(1)SY - Cisco
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
在原帖中查看解决方案
ilay
这个指的是Rommon的版本,rommon是初始化设备硬件并引导ios系统的一个引导程序,通常是独立升级的
这两个地方的version或者ios上的version才是代表的当前系统运行的版本,我看你发的链接是要升级这个ios
对应版本修复的bug可以查看相应版本的ReleaseNotes
漏洞或bug需要看是否影响当前功能或者业务,如果没受影响可以不做升级。例如:版本A.1有route-map和rip的漏洞,A.3版本做了修复,但在你实际环境里面并没有配置route-map和rip,那么A.1版本对你来说就是可用的,前面的bug修复不修复没有太大关系,并没有影响到你。所以解决不解决前面的漏洞得看你当前受哪些bug的影响,受影响则修复,不受影响则可以选择性升级
另 6807可以直接跨版本升级,直接上传对应版本ios并设置boot启动即可(升级前先查看releasenotes,确认硬件和软件的支持情况)
在原帖中查看解决方案
5 条回复5
None.
Identifier
Component
Description
CSCwb12806
cat6000-ipc
CSCwc49173
cat6000-l2
感谢老铁的回答,非常感谢
ilay
感谢老铁,真的非常感谢
老铁可以加个微信吗?
快捷链接
