取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
小白请教一个2960镜像口报错的问题
jialingwang4038
监控到镜像口一直有丢包,不知是正常吗,有啥办法解决。
FastEthernet0/11 is up, line protocol is down (monitoring)
Hardware is Fast Ethernet, address is 5835.d9dc.018b (bia 5835.d9dc.018b)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 3/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 14w1d, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 869217240
Queueing strategy: fifo
Output queue: 0/0 (size/max)
5 minute output rate 1445000 bits/sec, 853 packets/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
6375142851 packets output, 1958806912752 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
monitor session 1 source vlan 1
monitor session 1 destination interface Fa0/11
end
2 个已接受解答
已接受的解答
YilinChen
你的镜像配置是所有VLAN1 的流量,都镜像给FA0/11口,如果流量大于100M,你又是一个百兆口,丢包是正常的;
如果说是流量小于100M,检查一下物理网线吧,然后清下计数器,再观察。
在原帖中查看解决方案
2 条回复2
YilinChen
谢谢
快捷链接
