取消
显示结果
搜索替代
您的意思是:
查看次数
14
有帮助
回复
思科C2960X只能堆叠5台
zhangxllz
系统:c2960x-universalk9-mz-150-2a ex5
6台系统版本都一样,线缆连接合适,堆叠的时候只能堆叠5台,第6台加不进去!任意5台都可以堆叠!
4 条回复4
Lei Zhang
Hi, Sir
FlexStack-Plus technology creates a resilient single unified system (a stack) of up to eight switches in a homogeneous stack and up to four switches in a mixed stack. With a stack bandwidth of up to 80 Gbps, the stack functions as a single switching unit that is managed by the stack master. If the stack master fails, a new stack master is elected, keeping the stack operational. The new stack master is elected based on factors such as stack member priority value or lowest MAC address.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/release_notes/OL30810.html
Cisco Catalyst 2960-S, 2960-X, and 2960-XR Stacking with FlexStack and FlexStack-Plus Technology: Description, Usage, and Best Practices
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/white_paper_c11-728327.html
Thanks!
fortune
2960X 支持最大8台交换机堆叠,你这个确认所有版本都是一样么? 那你看看加入第6台设备的报错是什么,然后根据报错来处理,如果是正品可以找思科开case 这样就方便
qihouyang
是啊,应该是最大8台的
tangsen1991
2960X 支持最大8台交换机堆叠 建议更换机器,
快捷链接
