取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
求助,思科5960下挂的fex102报sftp错误日志
1749450065
大佬们,思科5960一直报这个是啥原因啊,显示的是下挂的fex102报错,是fex102自动向sftp发送东西导致的吗?
Hardware
cisco Nexus 5696 Chassis ("Nexus 5696 Supervisor")
Intel(R) Xeon(R) CPU @ 1.80 with 16511824 kB of memory.
2024 Feb 1 16:18:38 SHJQ-JY-5696-1 %SYSMGR-FEX102-3-CORE_OP_FAILED: Core operation failed: connect_and_upload_to_tftp: could not get tftp addr VDC: 1, idx: 0
2024 Feb 1 16:21:45 SHJQ-JY-5696-1 %SYSMGR-FEX102-3-CORE_OP_FAILED: Core operation failed: connect_and_upload_to_tftp: could not get tftp addr VDC: 1, idx: 0
2024 Feb 1 16:24:47 SHJQ-JY-5696-1 %SYSMGR-FEX102-3-CORE_OP_FAILED: Core operation failed: connect_and_upload_to_tftp: could not get tftp addr VDC: 1, idx: 0
2024 Feb 1 16:27:48 SHJQ-JY-5696-1 %SYSMGR-FEX102-3-CORE_OP_FAILED: Core operation failed: connect_and_upload_to_tftp: could not get tftp addr VDC: 1, idx: 0
2024 Feb 1 16:30:55 SHJQ-JY-5696-1 %SYSMGR-FEX102-3-CORE_OP_FAILED: Core operation failed: connect_and_upload_to_tftp: could not get tftp addr VDC: 1, idx: 0
2024 Feb 1 16:33:56 SHJQ-JY-5696-1 %SYSMGR-FEX102-3-CORE_OP_FAILED: Core operation failed: connect_and_upload_to_tftp: could not get tftp addr VDC: 1, idx: 0
2024 Feb 1 16:36:58 SHJQ-JY-5696-1 %SYSMGR-FEX102-3-CORE_OP_FAILED: Core operation failed: connect_and_upload_to_tftp: could not get tftp addr VDC: 1, idx: 0
2024 Feb 1 16:39:59 SHJQ-JY-5696-1 %SYSMGR-FEX102-3-CORE_OP_FAILED: Core operation failed: connect_and_upload_to_tftp: could not get tftp addr VDC: 1, idx: 0
2024 Feb 1 16:43:06 SHJQ-JY-5696-1 %SYSMGR-FEX102-3-CORE_OP_FAILED: Core operation failed: connect_and_upload_to_tftp: could not get tftp addr VDC: 1, idx: 0
2024 Feb 1 16:46:08 SHJQ-JY-5696-1 %SYSMGR-FEX102-3-CORE_OP_FAILED: Core operation failed: connect_and_upload_to_tftp: could not get tftp addr VDC: 1, idx: 0
2024 Feb 1 16:49:09 SHJQ-JY-5696-1 %SYSMGR-FEX102-3-CORE_OP_FAILED: Core operation failed: connect_and_upload_to_tftp: could not get tftp addr VDC: 1, idx: 0
2024 Feb 1 16:52:16 SHJQ-JY-5696-1 %SYSMGR-FEX102-3-CORE_OP_FAILED: Core operation failed: connect_and_upload_to_tftp: could not get tftp addr VDC: 1, idx: 0
3 条回复3
Tomatoeveryday
有可能是bug行为
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvp99738
not an operation impacting bug
Symptom: incorrect syslog when core copy fails.
Conditions: if core copy fails due to huge file size or tftp upload failure or file missing, incorrect syslog is printed.
Rockyw
@1749450065
思科5960的错误日志显示“Core operation failed: connect_and_upload_to_tftp: could not get tftp addr VDC: 1, idx: 0”,这表明在尝试通过TFTP协议连接并上传文件时遇到了问题。以下是可能的原因和解决方法:
  1. IP绑定问题
    • 确认TFTP服务器的IP地址是否正确,并且该IP地址在相应的网络配置中被正确绑定。例如,可以检查TFTP工具的设置,确保其绑定到与VPN相关的IP地址。
  2. 权限问题
    • 检查TFTP服务器目录的权限设置。确保目录具有适当的读写权限(例如,777权限),以便客户端能够成功上传文件。
  3. 网络连接问题
    • 确保网络连接正常,没有中断或延迟。如果网络不稳定,可能会导致连接失败。
  4. 服务器配置问题
    • 检查xinetd.d/tftpd配置文件中的参数设置,确保其包含正确的服务器参数(如-c -v -s /tftpboot),并确认目录具有适当的权限(如666权限)。
  5. 其他常见错误处理
    • 在实现TFTP客户端时,必须考虑各种可能出现的错误,并编写相应的错误处理代码,以应对网络中断、服务器拒绝连接等情况。
建议首先检查和确认TFTP服务器的IP绑定、权限设置以及网络连接情况,然后根据具体情况进行相应的调整和配置。
Rockyw | If it solves your problem, please mark as answer. Thanks !
Rockyw
另外 @1749450065 也可以参考一下下面的文档
Cisco Bug: CSCur57084
FEX Core Fails to Upload in Non-default VDC - No Workaround on NPE Image
https://bst.cisco.com/quickview/bug/CSCur57084
快捷链接
