取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
9
回复
请指教,2台 c2960x 断电不段重起問題?
D_W
有一台c2960x 断电不段重起,
另一台重起到以下位置就不动:
CPU rev: B
Image passed digital signature verification
Board rev: 24
Testing DataBus...
Testing AddressBus...
Testing Memory from 0x00000000 to 0x1fffffff.../
Using driver version 4 for media type 1
Xmodem file system is available.
Base ethernet MAC Address: 00:da:55:3c:e7:80
The password-recovery mechanism is enabled.
APM USBUSB EHCI 1.00
USB EHCI 1.00
USB Console INIT
Initializing Flash...
mifs[5]: 12 files, 1 directories
mifs[5]: Total bytes : 1806336
mifs[5]: Bytes used : 834560
mifs[5]: Bytes available : 971776
mifs[5]: mifs fsck took 0 seconds.
mifs[6]: 2 files, 1 directories
mifs[6]: Total bytes : 3870720
mifs[6]: Bytes used : 1213440
mifs[6]: Bytes available : 2657280
mifs[6]: mifs fsck took 1 seconds.
mifs[7]: 5 files, 1 directories
mifs[7]: Total bytes : 258048
mifs[7]: Bytes used : 8192
mifs[7]: Bytes available : 249856
mifs[7]: mifs fsck took 0 seconds.
mifs[8]: 5 files, 1 directories
mifs[8]: Total bytes : 258048
mifs[8]: Bytes used : 8192
mifs[8]: Bytes available : 249856
mifs[8]: mifs fsck took 1 seconds.
mifs[9]: 627 files, 20 directories
mifs[9]: Total bytes : 122185728
mifs[9]: Bytes used : 50477568
mifs[9]: Bytes available : 71708160
mifs[9]: mifs fsck took 51 seconds.
...done Initializing Flash.
Loading "flash:c2960x-universalk9-mz.152-7.E5.bin"...Verifying image flash:c2960x-universalk9-mz.152-7.E5.bin.........................................................................................................................................................................................................................................................................................................................................................................................................................Image passed digital signature verification
File "flash:c2960x-universalk9-mz.152-7.E5.bin" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(7)E5, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Mon 13-Sep-21 09:41 by mcpre
Initializing flashfs...
mifs[7]: 12 files, 1 directories
mifs[7]: Total bytes : 1806336
mifs[7]: Bytes used : 834560
mifs[7]: Bytes available : 971776
mifs[7]: Initialization complete.
mifs[8]: 2 files, 1 directories
mifs[8]: Total bytes : 3870720
mifs[8]: Bytes used : 1213440
mifs[8]: Bytes available : 2657280
mifs[8]: Initialization complete.
mifs[9]: 5 files, 1 directories
mifs[9]: Total bytes : 258048
mifs[9]: Bytes used : 8192
mifs[9]: Bytes available : 249856
mifs[9]: mifs fsck took 0 seconds.
mifs[9]: Initialization complete.
mifs[10]: 5 files, 1 directories
mifs[10]: Total bytes : 258048
mifs[10]: Bytes used : 8192
mifs[10]: Bytes available : 249856
mifs[10]: mifs fsck took 0 seconds.
mifs[10]: Initialization complete.
mifs[11]: 627 files, 20 directories
mifs[11]: Total bytes : 122185728
mifs[11]: Bytes used : 50477568
mifs[11]: Bytes available : 71708160
mifs[11]: mifs fsck took 1 seconds.
mifs[11]: Initialization complete.
...done Initializing flashfs.
Checking for Bootloader upgrade..
Boot Loader upgrade not needed(v)
FIPS: Flash Key Check : Begin
FIPS: Flash Key Check : End, Not Found, FIPS Mode Not Enabled
extracting front_end/front_end_ucode_info (43 bytes)
Software version is different so extracting
the whole bundle
extracting ucode_info (76 bytes)
front_end/ (directory)
extracting front_end/fe_type_9 (82197 bytes)
Front-end Microcode IMG MGR: Installed 1 image(s) in cache:
Front-end Microcode IMG MGR: found microcode images for 1 devices.
Image for front-end 0: flash:/front_end_ucode_cache/ucode.0
Front-end Microcode IMG MGR: Preparing to program device microcode...
Front-end Microcode IMG MGR: Preparing to program device[0]...29204 bytes.
Front-end Microcode IMG MGR: Programming device 0...rrrrrrwssssssss
% Front-end Microcode IMG MGR: address 0, PROGRAM failed
% Front-end Microcode IMG MGR: unable to program device: 0
% Front-end Microcode IMG MGR: malformed microcode cache
POST: MA BIST : Begin
POST: MA BIST : End, Status Passed
POST: TCAM BIST : Begin
POST: TCAM BIST : End, Status Passed
POST: ACT2 Authentication : Begin
POST: ACT2 Authentication : End, Status Passed
Waiting for Stack Master Election...
POST: Thermal, Fan Tests : Begin   到这里就不动
试过按 Mode ,用4G 的U盘读不到,(FAT16/32)都试过,U盘是沒問題,其他交換机可以读到
switch: flash_init
switch:dir usbflash0:
ERR: usbd_bulk_transfer fail status 32
ERR: Read ERROR start 0 blks 1
ERR: !CSWSIGNATURE
usbflash0: contains unexpected values in partition table or boot sector,
Device needs formatting before use!
unable to stat usbflash0:/: unknown error
9 条回复9
YilinChen
2台C2960X是不做了堆叠?
根据楼主上述启动log,首先可以判定设备本身硬件没什么大问题,IOS解压加载到内存都是正常的,后续启动日志中,有关键性的2处报错:
1、Software version is different so extracting the whole bundle
2、% Front-end Microcode IMG MGR: address 0, PROGRAM failed
推测是这台C2960的IOS版本和另一台不一致导致的,建议明确这台设备的IOS版本,如果有堆叠,那就先单独升级这台设备的IOS版本,统一版本后,再重新加到堆叠组里
这2台是单独的,不是堆叠.
YilinChen
如果是单独设备,建议还是通过完整tar包,重新安装一下IOS,再观查是否能正常进入系统。
 現在系統起动不了,只能按MODE 进入Switch:
在Switch: 怎样安裝tar包 ?
YilinChen
如果是在rommon模式下,可以先执行flash_init和load_helper,然后dir检查FLASH下的ISO文件,看看有几个版本,并通过boot命令尝试加载;
switch: flash_init
switch: load_helper
switch: dir flash:
switch: boot flash:xxxx.bin
参考链接:https://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/41845-192.html
如果是能正常进入系统,升级可参考下面的链接:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/file_management/file_management/img_files.html
引导帮助程序沒起作用?
switch: flash_init
...The flash is already initialized.
switch: load_helper
Unknown cmd: load_helper
YilinChen
根据你贴上信息,FLASH是正常的,只是你对在Rommon模式下的命令行还不熟,建议多打?号验证检查有哪些可用命令,并参考以下链接:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-2_7_e/b_1527e_consolidated_2960x_cg/m_sm_trbl_cg_c2k.html#task_477BAE1EA7C04A8D8432A40E223B2F46
wangyan1
想问下楼主这个问题最终怎么解决的,我遇到了同样的问题
shengluan
快捷链接
