取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
请教各位大佬,这个交换机出现故障的原因
zjwbjm
今天在调试交换机时出现以下情况,而且不停重启,请问有大佬知道出现这种情况的原因吗?在此感激不尽
CPU rev: B
Board rev: 5
Testing DataBus...
Testing AddressBus...
Testing Memory from 0x00000000 to 0x1fffffff.../
Using driver version 4 for media type 1
Xmodem file system is available.
Base ethernet MAC Address: 04:31:10:40:4b:80
The password-recovery mechanism is enabled.
USB EHCI 1.00
USB EHCI 1.00
USB Console INIT
Initializing Flash...
mifs[5]: 12 files, 1 directories
mifs[5]: Total bytes : 1806336
mifs[5]: Bytes used : 833536
mifs[5]: Bytes available : 972800
mifs[5]: mifs fsck took 0 seconds.
mifs[6]: 2 files, 1 directories
mifs[6]: Total bytes : 3870720
mifs[6]: Bytes used : 1213440
mifs[6]: Bytes available : 2657280
mifs[6]: mifs fsck took 0 seconds.
mifs[7]: 5 files, 1 directories
mifs[7]: Total bytes : 258048
mifs[7]: Bytes used : 8192
mifs[7]: Bytes available : 249856
mifs[7]: mifs fsck took 0 seconds.
mifs[8]: 5 files, 1 directories
mifs[8]: Total bytes : 258048
mifs[8]: Bytes used : 8192
mifs[8]: Bytes available : 249856
mifs[8]: mifs fsck took 1 seconds.
mifs[9]: 845 files, 21 directories
mifs[9]: Total bytes : 122185728
mifs[9]: Bytes used : 73874432
mifs[9]: Bytes available : 48311296
mifs[9]: mifs fsck took 65 seconds.
...done Initializing Flash.
Loading "flash:/c2960x-universalk9-mz.152-2.E5/c2960x-universalk9-mz.152-2.E5.bin"...Verifying image flash:/c2960x-universalk9-mz.152-2.E5/c2960x-universalk9-mz.152-2.E5.bin.....................................................................................................................................................................................................................................................................................................................................Image passed digital signature verification
File "flash:/c2960x-universalk9-mz.152-2.E5/c2960x-universalk9-mz.152-2.E5.bin" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(2)E5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Thu 02-Jun-16 01:31 by prod_rel_team
Initializing flashfs...
mifs[7]: 12 files, 1 directories
mifs[7]: Total bytes : 1806336
mifs[7]: Bytes used : 833536
mifs[7]: Bytes available : 972800
mifs[7]: Initialization complete.
mifs[8]: 2 files, 1 directories
mifs[8]: Total bytes : 3870720
mifs[8]: Bytes used : 1213440
mifs[8]: Bytes available : 2657280
mifs[8]: mifs fsck took 0 seconds.
mifs[8]: Initialization complete.
mifs[9]: 5 files, 1 directories
mifs[9]: Total bytes : 258048
mifs[9]: Bytes used : 8192
mifs[9]: Bytes available : 249856
mifs[9]: mifs fsck took 0 seconds.
mifs[9]: Initialization complete.
mifs[10]: 5 files, 1 directories
mifs[10]: Total bytes : 258048
mifs[10]: Bytes used : 8192
mifs[10]: Bytes available : 249856
mifs[10]: mifs fsck took 1 seconds.
mifs[10]: Initialization complete.
mifs[11]: 845 files, 21 directories
mifs[11]: Total bytes : 122185728
mifs[11]: Bytes used : 73874432
mifs[11]: Bytes available : 48311296
mifs[11]: mifs fsck took 1 seconds.
mifs[11]: Initialization complete.
...done Initializing flashfs.
Checking for Bootloader upgrade..
Boot Loader upgrade not required (Stage 2)
FIPS: Flash Key Check : Begin
FIPS: Flash Key Check : End, Not Found, FIPS Mode Not Enabled
POST: MA BIST : Begin***ERR: S88G MDIO Read - Address is not decoded.
POST: MA BIST : End, Status Failed
POST: BIST failed
POST: ACT2 Authentication : Begin
POST: ACT2 Authentication : End, Status Passed
driver class subsystem initialization failed
23:45:34 UTC Sat Apr 8 2000: Unexpected exception to CPUvector 300, PC = 2C88424
-Traceback= 0x2C88424z 0x2B8D834z 0x2B89F34z 0x2B86A54z 0x219E4ECz 0x219E6C8z 0x219E840z 0x566E80z 0x5670A8z 0x2E2BD04z 0x2E27A00z
Writing crashinfo to flash:/crashinfo_ext/crashinfo_ext_194
=== Flushing messages (23:45:48 UTC Sat Apr 8 2000) ===
Buffered messages:
Queued messages:
Apr 8 23:45:48.624: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Mar 1 00:00:57.262: Read env variable - LICENSE_BOOT_LEVEL =
*Jan 2 00:00:00.087: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2960x_lanbase Next reboot level = lanbase and License = lanbase
Apr 8 23:45:28.991: Flexstack module is 1
Apr 8 23:45:29.085: %HPAA:hpaa_port_bitmap_init:254:n_ports = 52, sizeof (**hpaa_port_bitmap.bitlist_array) = 16
Apr 8 23:45:34.048: %PLATFORM_IPC-3-COMMON: Init failed before IPC init
-Traceback= 555260z 28226C4z 29517F8z 219E4ECz 219E6C8z 219E840z 566E38z 5670A8z 2E2BD04z 2E27A00z
Apr 8 23:45:34.153: platform assert failure: 0: ../src-hulc/src-strider/strider_hqatm.c: 5446: strider_hqatm_set_snap_bridging
Apr 8 23:45:34.153: -Traceback= 5566D4z 294F31Cz 2BA27D0z 281E32Cz 219E4ECz 219E6C8z 219E840z 566E80z 5670A8z 2E2BD04z 2E27A00z
Data Access Exception (0x0300)!
SRR0 = 0x02C88424 SRR1 = 0x00029200 SRR2 = 0x02FF0B68 SRR3 = 0x00029200
ESR = 0x00800000 DEAR = 0x00000B00 TSR = 0x84000000 DBSR = 0x00000000
CPU Register Context:
Vector = 0x00000300 PC = 0x02C88424 MSR = 0x00029200 CR = 0x59000039
LR = 0x02B8D834 CTR = 0x00486D7C XER = 0xE000006C
R0 = 0x780A43A6 R1 = 0x05B279C8 R2 = 0x00000000 R3 = 0x00000B00
R4 = 0x00000000 R5 = 0x00042805 R6 = 0xC0000B00 R7 = 0x0000000A
R8 = 0x7C7043A6 R9 = 0x00000010 R10 = 0x010A0170 R11 = 0x000A0000
R12 = 0x0000000B R13 = 0x1F183AA8 R14 = 0x0056704C R15 = 0x00000000
R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000000
R24 = 0x00000000 R25 = 0x00000000 R26 = 0x00000000 R27 = 0x041F0000
R28 = 0x00000000 R29 = 0x05B279F8 R30 = 0x00000000 R31 = 0x05306AEC
Stack trace:
PC = 0x02C88424, SP = 0x05B279C8
Frame 00: SP = 0x05B279D0 PC = 0x0360B84C
Frame 01: SP = 0x05B279E8 PC = 0x02B89F34
Frame 02: SP = 0x05B27A28 PC = 0x02B86A54
Frame 03: SP = 0x05B27A38 PC = 0x0219E4EC
Frame 04: SP = 0x05B27A58 PC = 0x0219E6C8
Frame 05: SP = 0x05B27A70 PC = 0x0219E840
Frame 06: SP = 0x05B27AA0 PC = 0x00566E80
Frame 07: SP = 0x05B27BA0 PC = 0x005670A8
Frame 08: SP = 0x05B27BA8 PC = 0x02E2BD04
Frame 09: SP = 0x00000000 PC = 0x02E27A00
Switch uptime is 1 minute, 26 seconds
cisco WS-C2960X-48FPD-L (APM86XXX) processor (revision M0) with 524288K bytes of memory.
Processor board ID FOC2203V084
1 个已接受解答
已接受的解答
YilinChen
尝试格式化FLASH,重新上传ISO镜像,如果还这样,就返厂报修吧,
如果要急着临时使用,还可以尝试USB外接U盘,手动指定引导路径;
在原帖中查看解决方案
3 条回复3
YilinChen
wuhao0015
可直接RMA啦。。。 .
2095316477
如果是经常这样不停重启,还是 RMA 保险。免得后续在产线环境下重启,那就悲剧了~
快捷链接
