取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
请问9200支持ip sla吗?
luke.zhang
最近客户的3750X要升级为9200,我在把配置刷到9200上发现关于sla的命令刷不上去
Switch(config)#ip sla ?
key-chain Use MD5 Authentication for IP SLAs Control Messages
responder Enable IP SLAs Responder
server IPPM server configuration
请问怎么才能配置sla? 谢谢
2 个已接受解答
已接受的解答
我看了一下17.3.x的配置,有SLA的配置,所以应该是支持的!
Restrictions on SLAs
This section lists the restrictions on SLAs.
The following are restrictions on IP SLAs network performance measurement:
  • The device does not support VoIP service levels using the gatekeeper registration delay operations measurements.
  • Only a Cisco IOS device can be a source for a destination IP SLAs responder.
  • You cannot configure the IP SLAs responder on non-Cisco devices and Cisco IOS IP SLAs can send operational packets only to services native to those devices.
Feature Information for Service Level Agreements
The following table provides release information about the feature or features described in this module. This table lists only the software release that introduced support for a given feature in a given software release train. Unless noted otherwise, subsequent releases of that software release train also support that feature.
Use Cisco Feature Navigator to find information about platform support and Cisco software image support. To access Cisco Feature Navigator, go to www.cisco.com/go/cfn. An account on Cisco.com is not required.
Table 2. Feature Information for Service Level Agreements
Releases
Feature Information
Cisco IOS XE Fuji 16.9.2
This feature was introduced.
更详细的配置和注意事项请参考:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9200/software/release/17-3/configuration_guide/nmgmt/b_173_nmgmt_9200_cg/configuring_service_level_agreements.html#reference_ff2_mw4_mgb
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
在原帖中查看解决方案
此外,注意一下license
Features on Cisco Catalyst uplink switches
Network Essentials
Network Advantage
Switch fundamentals
Layer 2, Routed Access (RIP, EIGRP Stub, OSPF -– 1000 routes), PBR, PIM Stub Multicast (1000 routes), PVLAN, VRRP, PBR, CDP, QoS, FHS, 802.1X, MACsec-128, CoPP, SXP, IP SLA Responder, SSO
Yes
Yes
Advanced switch capabilities and scale
EIGRP, HSRP, IS-IS, BSR, MSDP, IP SLA, OSPF
No
Yes
在原帖中查看解决方案
2 条回复2
Releases
Feature Information
更详细的配置和注意事项请参考:
此外,注意一下license
Network Essentials
Network Advantage
Switch fundamentals
Yes
Yes
No
Yes
快捷链接
