本帖最后由 iosvip@163.com 于 2018-6-27 08:59 编辑 Rocky 发表于 2018-6-26 23:02
IOS 12.2(52)SE之前的软件版本,不受Smart Install安全漏洞影响,所以就没有这命令。
IOS 12.2(52)SE 当前这个版本,本身有监听TCP.4786 端口,且show vstack也能看到作为客户端的信息,但没有关闭该服务的命令。是否有其他解决方法?thx.
xxx-C3560-24TS#show ver
Cisco IOS Software, C3560 Software (C3560-IPSERVICESK9-M), Version 12.2(52)SE, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 25-Sep-09 08:13 by sasyamal
Image text-base: 0x01000000, data-base: 0x02E00000
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(50r)SE, RELEASE SOFTWARE (fc1)
dqg-C3560-24TS uptime is 1 day, 22 hours, 58 minutes
System image file is "flash:c3560-ipservicesk9-mz.122-52.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.htmlIf you require further assistance please contact us by sending email to
export@cisco.com.
cisco WS-C3560V2-24TS (PowerPC405) processor (revision F0) with 131072K bytes of memory.
Processor board ID FDO1439X286
Last reset from power-on
2 Virtual Ethernet interfaces
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : B4:14:89:10:D7:00
Motherboard assembly number : 73-11765-08
Power supply part number : 341-0328-02
Motherboard serial number : FDO143911KV
Power supply serial number : DCA1428M4JV
Model revision number : F0
Motherboard revision number : A0
Model number : WS-C3560V2-24TS-S
System serial number : FDO1439xxx6
Top Assembly Part Number : 800-31050-04
Top Assembly Revision Number : A0
Version ID : V04
CLEI Code Number : COMP900ARA
Hardware Board Revision Number : 0x03
Switch Ports Model SW Version SW Image
* 1 26 WS-C3560V2-24TS 12.2(52)SE C3560-IPSERVICESK9-M
Configuration register is 0xF
xx-C3560-24TS#show vs conf Role: Client
Vstack Director IP address: 0.0.0.0
*** Following configurations will be effective only on director ***
Vstack default management vlan: 1
Vstack management Vlans: none
xx-C3560-24TS#conf t
Enter configuration commands, one per line. End with CNTL/Z.
xx-C3560-24TS(config)#no vs
xx-C3560-24TS(config)#no vstack
% Incomplete command.
xxg-C3560-24TS(config)#no vstack config
xxg-C3560-24TS(config)#end
xxg-C3560-24TS#show tcp br all
TCB Local Address Foreign Address (state)
04F65F88 10.x.128.14.22 10.x.33.91.14176 ESTAB
04F37D28 *.4786 *.* LISTEN
