取消
显示结果
搜索替代
您的意思是:
查看次数
15
有帮助
回复
Catalyst 2960-x交换机跨设备端口聚合是否支持?
jasonzeng3110
2 个已接受解答
已接受的解答
YilinChen
EtherChannel on Switches
You can create an EtherChannel on a switch, on a single switch in the stack, or on multiple switches in the stack (known as cross-stack EtherChannel).
Restrictions for EtherChannels
  • All ports in an EtherChannel must be assigned to the same VLAN or they must be configured as trunk ports.
  • When the ports in an EtherChannel are configured as trunk ports, all the ports must be configured with the same mode (either Inter-Switch Link [ISL] or IEEE 802.1Q).
  • Port Aggregation Protocol (PAgP) can be enabled only in single-switch EtherChannel configurations; PAgP cannnot be enabled on cross-stack EtherChannels.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-2_2_e/consolidated_guide/configuration_guide/b_1522e_consolidated_2960x_cg/b_consolidated_152ex_2960-X_cg_chapter_010010.html
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
在原帖中查看解决方案
4 条回复4
YilinChen
谢谢您的答复。
Thanks, Your answers are very helpful to me
快捷链接
