取消
显示结果
搜索替代
您的意思是:
查看次数
18
有帮助
6
回复
cisco 4506 cpu 高!!!
topnewinfo
JT-4506-1#sh proc cpu so 5se
CPU utilization for five seconds: 32%/0%; one minute: 30%; five minutes: 31%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
58 8818750353707169302 0 21.19% 17.64% 18.35% 0 Cat4k Mgmt LoPri
57 2535818316 443647374 5715 7.27% 7.83% 7.88% 0 Cat4k Mgmt HiPri
109 431437899 749682568 575 0.79% 0.93% 0.98% 0 IP Input
14 2890879741522020496 189 0.47% 0.61% 0.59% 0 ARP Input
116 103254436 378426195 272 0.39% 0.39% 0.39% 0 Spanning Tree
112 2657381781294108349 205 0.31% 1.06% 0.86% 0 ADJ resolve proc
JT-4506-1#sh pl health
%CPU %CPU RunTimeMax Priority Average %CPU Total
Target Actual Target Actual Fg Bg 5Sec Min Hour CPU
K2CpuMan Review 30.00 10.39 30 38 100 500 10 9 7 60459:30 cpu抓包没有什么异常
这两个高!!
K2L2 Address Table R 2.00 18.99 12 5 100 500 12 9 7 51455:59
K2FibAdjMan Host Mov 2.00 12.43 10 7 100 500 8 8 7 11238:47
JT-4506-1#sh mac add aging-time
Vlan Aging Time Configured Aging Time
Global Vlan Admin Age: 300
1 300 300
100 300 300
300 300 300
500 300 300
501 300 300
502 300 300
503 300 300
600 15 300 vlan600 没有设置什么,但不知道为什么aging time 是15
601 300 300
JT-4506-1#sh version
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICESK9-M), Version 12.2(54)SG, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sun 27-Jun-10 00:29 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x123F21AC
ROM: 12.2(31r)SGA3
Pod Revision 16, Force Revision 31, Tie Revision 32
JT-4506-1 uptime is 2 years, 7 weeks, 16 minutes
System restarted at 15:56:40 BeiJing Tue Nov 29 2011
System image file is "bootflash:cat4500-entservicesk9-mz.122-54.sg.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C4506-E (MPC8540) processor (revision 13) with 524288K bytes of memory.
Processor board ID FOX1524GGAV
MPC8540 CPU at 800Mhz, Supervisor V-10GE
Last reset from PowerUp
6 Virtual Ethernet interfaces
106 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
求帮忙解决!!!谢谢!!!
6 条回复6
topnewinfo
版主呢?高手呢?帮帮忙啊!!!!
Sullivan
如果可以做Debug,可以做个debug查查原因. (如果是重要核心网络,请慎用)
1. debug platform packet all receive buffer
2. show platform CPU packet buffered
3.get the summary for source and destination port,and src and dst MAC address
scdxqwpw
只能做相关DEBUG了
yyc25160760
等高手出现
764963038cisco
千万别随便debug
Lei Zhang
果断的应该有2层环路~
K2L2 Address Table R + K2FibAdjMan Host Mov 这两个都是在说2层的事,一个是mac地址表,一个是说FIB 的邻接表。。。
1、配个mac notification,看看是不是有大量的mac地址在move、change
2、检查一下topo内几台设备的stp是否正常(一定要在high cpu时做)
3、debug platform packet all receive buffer,这个命令一定要在high cpu的时候做才有意义,另外,不用担心这个命令会增加cpu负载。这个命令和传统的debug是不一样的,可以放心使用。随后,show platform CPU packet buffered 来查看debug的结果。
4、如果还有问题,请联系Cisco TAC,开case,TAC会帮您解决。
快捷链接
