取消
显示结果
搜索替代
您的意思是:
查看次数
14
有帮助
回复
cisco 6509 部分端口ping不通
小斌
------------------ show version ------------------
Cisco IOS Software, s2t54 Software (s2t54-ADVIPSERVICESK9-M), Version 15.1(2)SY, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 04-Sep-13 12:37 by prod_rel_team
ROM: System Bootstrap, Version 12.2(50r)SYS3, RELEASE SOFTWARE (fc1)
GDDS-VS6509 uptime is 3 years, 3 days, 15 hours, 17 minutes
Uptime for this control processor is 1 year, 14 weeks, 6 days, 4 hours, 45 minutes
System returned to ROM by Stateful Switchover at 13:24:09 UTC Mon Jun 6 2016
System restarted at 21:26:25 UTC Mon Jun 6 2016
System image file is "bootdisk:s2t54-advipservicesk9-mz.SPA.151-2.SY.bin"
Last reload reason: unknown reload cause - reason ptr 0x17, PC 0x527F7E0, address 0x527F7E0
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
interface TenGigabitEthernet2/6/3
description bad port
no switchport
no ip address
TenGigabitEthernet2/6/3 is down, line protocol is down (notconnect)
Hardware is C6k 10000Mb 802.3, address is b4e9.b0c8.dd00 (bia b4e9.b0c8.dd00)
Description: bad port
MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
reliability 255/255, txload 0/255, rxload 0/255
Keepalive set (10 sec)
Full-duplex, 10Gb/s
input flow-control is off, output flow-control is off
Clock mode is auto
Last input 00:04:26, output never, output hang never
Last clearing of "show interface" counters 00:13:46
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 3766602026
Queueing strategy: fifo
Output queue: 0/40 (size/max)
L2 Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
L3 out Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
48471 packets input, 4959812 bytes, 0 no buffer
Received 48469 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 2 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 2797300 pause input
1028744917844 packets output, 697102243319577 bytes, 0 underruns
3 条回复3
fortune
(notconnect 是表示物理down,你要测试下 线缆跟PC 测试下看看,如果一直都是down的,有模块看看更换个好的模块试试看。 如果还是down,估计是端口坏了的说
jingjian
根据端口的状态显示二层连接有问题,
1.请检查你的跳线是否有问题,可以把此跳线连接到其他的空接口,查看端口是否可以up,从而可以判断跳线是否有问题。
2可以把此接口的光模块和其他接口的光模块互换,判断此模块和端口是否有问题
通过上面的测试基本可以确认问题的原因
RenxChen
PING不通是有很多原因,从贴的配置,
只能看到描述是bad
并且没有连接,二层协议down
还是个三层接口,没有配置IP
no switchport
no ip address。
可以给接口配个地址,直连个设备看下能不能ping。
快捷链接
