取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
CISCO WS-C4948-10G 莫名重启,求分析
leimin fan
型号:WS-C4948-10G, IOS:cat4500-entservices-mz.122-52.SG.bin
早上交换机莫名就重启, 没有做任何操作。 收集了show tech信息, 从中并没有看出什么端倪。因设备过保了, 也只能求助大家一起分析一下当前信息。
------------------ show clock ------------------
*00:34:51.891 GTM Tue Jun 14 2016
------------------ show version ------------------
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICES-M), Version 12.2(52)SG, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Tue 12-May-09 17:58 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x11F07228
ROM: 12.2(31r)SGA4
Pod Revision 0, Force Revision 31, Gill Revision 19
C1-Core254 uptime is 2 hours, 1 minute
System returned to ROM by reload
System image file is "bootflash:cat4500-entservices-mz.122-52.SG.bin"
cisco WS-C4948-10GE (MPC8540) processor (revision 5) with 262144K bytes of memory.
Processor board ID FOX1330GM8Y
MPC8540 CPU at 667Mhz, Fixed Module
Last reset from Reload
3 Virtual Ethernet interfaces
48 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
系统恢复后登陆交换机查看CPU和内存, 使用率并不高
------------------ show memory statistics ------------------
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 12F94ABC 218543424 156403036 62140388 60627220 61835776
------------------ show process memory ------------------
Processor Pool Total: 218543424 Used: 156397804 Free: 62145620
PID TTY Allocated Freed Holding Getbufs Retbufs Process
0 0 130217336 4575292 115826856 0 0 *Init*
0 0 13136 819604 13136 0 0 *Sched*
0 0 23288376 2732336 22955364 6573448 0 *Dead*
1 0 45224 3088 75060 0 0 Chunk Manager
2 0 180 180 29924 0 0 Load Meter
3 0 216 0 33176 0 0 CEF RP IPC Backg
4 0 0 0 32924 0 0 Deferred Events
5 0 0 0 32924 0 0 Retransmission o
6 0 0 0 32924 0 0 IPC ISSU Receive
7 0 0 0 32924 0 0 Check heaps
8 0 0 0 32924 0 0 Pool Manager
9 0 180 180 32924 0 0 Timers
10 0 908 908 32992 0 0 PrstVbl
11 0 180 180 32924 0 0 Serial Backgroun
12 0 0 0 50924 0 0 Crash writer
13 0 0 0 32924 0 0 ifIndex Receive
14 0 5751100 1904 5743504 0 0 ARP Input
15 0 0 0 32924 0 0 CEF MIB API
16 0 0 0 32924 0 0 AAA_SERVER_DEADT
17 0 180 180 32924 0 0 AAA high-capacit
18 0 0 0 38924 0 0 Policy Manager
19 0 51640 47016 73000 0 7540 Entity MIB API
20 0 230560 0 266484 99792 0 EEM ED Syslog
21 0 0 0 32924 0 0 IFS Agent Manage
22 0 0 0 32924 0 0 IPC Dynamic Cach
23 0 0 0 32924 0 0 IPC Zone Manager
24 0 0 0 32924 0 0 IPC Periodic Tim
25 0 0 0 32924 0 0 IPC Managed Time
26 0 0 0 32924 0 0 IPC Deferred Por
27 0 1688 0 34612 0 0 IPC Seat Manager
28 0 0 0 32924 0 0 IPC Session Serv
29 0 0 0 32924 0 0 client_entity_se
30 0 0 0 32924 0 0 SERIAL A'detect
31 0 0 0 32924 0 0 ARP Snoop
32 0 0 0 32924 0 0 Dynamic ARP Insp
33 0 180 180 32924 0 0 GraphIt
34 0 0 0 32924 0 0 Critical Bkgnd
35 0 66480 0 39556 0 0 Net Background
36 0 69413008 69413008 38924 0 0 IDB Work
37 0 180 180 38924 0 0 Logger
38 0 180 432 35924 0 0 TTY Background
39 0 69100 69100 32924 0 0 Per-Second Jobs
40 0 2936000 0 2968924 1016000 0 Per-minute Jobs
41 0 4712 65580 37636 0 0 IF-MGR control p
42 0 0 0 32924 0 0 IF-MGR event pro
43 0 0 0 32924 0 0 ISSU PROCESS IPC
44 0 0 0 32924 0 0 PrstVbl IPC Msg
45 0 0 0 32924 0 0 cpf_msg_holdq_pr
46 0 0 0 32924 0 0 cpf_msg_rcvq_pro
47 0 180 180 35924 0 0 IP Host Track HA
48 0 0 0 32924 0 0 ARP HA
49 0 0 0 35924 0 0 IP Admission HA
50 0 0 0 32924 0 0 Network-rf Notif
51 0 2017004 1390276 525312 0 0 Cat4k Mgmt HiPri
52 0 113124 120644 108156 0 0 Cat4k Mgmt LoPri
53 0 0 0 32924 0 0 Galios Reschedul
54 0 0 0 32924 0 0 IOS ACL Helper
55 0 0 0 32924 0 0 BACK CHECK
56 0 146636 0 113712 0 0 rf task
57 0 0 0 32924 0 0 RF High Priority
58 0 0 0 32924 0 0 Net Input
59 0 204 204 32924 0 0 Compute load avg
60 0 0 0 32924 0 0 cpf_process_tpQ
61 0 0 0 32924 0 0 AggMgr Process
62 0 0 608 32924 0 0 Transport Port A
63 0 0 0 32924 0 0 HC Counter Timer
64 0 0 0 32924 0 0 SFF8472
65 0 180 180 35924 0 0 Ethernet OAM Pro
66 0 0 0 32924 0 0 PPPOE IA
67 0 180 180 32924 0 0 REP Topology cha
68 0 180 180 32924 0 0 Auth Manager
69 0 180 180 32924 0 0 Dot1x Mgr Proces
70 0 0 0 32924 0 0 MAB Framework
71 0 0 0 32924 0 0 AUTH POLICY Fram
72 0 0 0 32924 0 0 802.1x Webauth F
73 0 0 7984 32924 0 0 802.1x switch
74 0 828 180 33572 0 0 DTP Protocol
75 0 0 0 32924 0 0 EAP Framework
76 0 216 0 33140 0 0 Port-Security
77 0 180 180 38924 0 0 Ethernet CFM
78 0 180 180 38924 0 0 Ethernet Timer C
79 0 180 180 32924 0 0 EFP Errd
80 0 472 180 33216 0 0 UDLD
81 0 180 180 35924 0 0 IP Host Track Pr
82 0 71308 0 104232 0 0 Switch Backup In
83 0 0 0 32924 0 0 MMN bkgrd proces
84 0 0 0 32924 0 0 powernet proxy t
85 0 294304 291644 35584 0 0 powernet proxy u
86 0 180 180 32924 0 0 Ethchnl
87 0 180 180 32924 0 0 AAA Server
88 0 0 0 32924 0 0 AAA ACCT Proc
89 0 0 0 32924 0 0 ACCT Periodic Pr
90 0 0 0 32948 0 0 AAA System Acct
91 0 0 0 32924 0 0 Auth-proxy AAA B
92 0 0 0 32924 0 0 IP Admin SM Proc
93 0 164940 141948 58984 0 0 CDP Protocol
94 0 233492 90160 32924 0 0 SpanTree Helper
95 0 0 0 32924 0 0 Call Home Timer
96 0 204 204 32924 0 0 AAA Dictionary R
97 0 0 0 32924 0 0 DHCP Snooping
98 0 180 180 35924 0 0 EAPoUDP Process
99 0 420 180 39164 0 0 CEF switching ba
100 0 10024 0 46220 0 0 IP Input
101 0 0 0 32924 0 0 ICMP event handl
102 0 180 180 35924 0 0 IP ARP Track
103 0 1016 180 39760 0 0 ADJ resolve proc
104 0 0 0 32924 0 0 IPv6 Echo event
105 0 216 0 39140 0 0 Collection proce
106 0 72084 3876 33140 0 0 Spanning Tree
107 0 576 592 39172 0 0 CEF background p
108 0 0 0 35924 0 0 IP IRDP
109 0 0 0 32924 0 0 XDR mcast
110 0 0 0 32924 0 0 IPC LC Message H
111 0 0 0 32924 0 0 XDR RP Ping Back
112 0 0 0 32924 0 0 XDR RP backgroun
113 0 0 0 32924 0 0 XDR RP Test Back
114 0 152 2424 38924 0 0 TCP Timer
115 0 186540 0 38924 0 0 TCP Protocols
116 0 0 0 32924 0 0 Socket Timers
117 0 11552 4808 42516 0 0 HTTP CORE
118 0 180 180 32924 0 0 Cluster L2
119 0 0 0 32924 0 0 Cluster RARP
120 0 0 0 50924 0 0 COPS
121 0 0 0 32924 0 0 Probe Input
122 0 0 0 32924 0 0 RARP Input
123 0 180 180 32924 0 0 REP LSL Proc
124 0 10224 180 42968 0 0 REP BPA/EPA Proc
125 0 0 0 32924 0 0 Critical Auth
126 0 6056 12000 37016 0 0 L2MM
127 0 100 0 33024 0 0 MRD
128 0 1416468 1351804 97588 0 0 IGMPSN
129 0 0 0 32924 0 0 IGMPQR
130 0 33100 270480 36928 0 0 MLDSN L2MCM
131 0 0 0 32924 0 0 MRD
132 0 0 0 32924 0 0 MLD_SNOOP
133 0 2948 180 35692 0 0 L2TRACE SERVER
134 0 0 0 32924 0 0 IGMPSN-HA
135 0 0 0 32924 0 0 DHCP Snooping HA
136 0 180 180 32924 0 0 ATIP_UDP_TSK
137 0 144 0 36068 0 0 IP Background
138 0 145996 0 181920 0 0 IP RIB Update
139 0 92200 180 65096 0 0 DHCPD Receive
140 0 0 0 32924 0 0 HSRP HA
141 0 266704 364 272040 0 0 CEF: IPv4 proces
142 0 216 0 33140 0 0 ADJ background
143 0 0 0 32924 0 0 CFMPAL Process
144 0 0 0 32924 0 0 EPM MAIN PROCESS
145 0 0 0 32924 0 0 EM Background Pr
146 0 180 180 32924 0 0 LOCAL AAA
147 0 180 180 32924 0 0 ENABLE AAA
148 0 180 180 32924 0 0 LINE AAA
150 0 2084 180 34828 0 0 TPLUS
151 0 180 180 32924 0 0 VTPMIB EDIT BUFF
152 0 180 180 32924 0 0 DHCP Security He
153 0 76 312 32924 0 0 DiagCard1/-1
154 0 19816 19744 33140 0 0 Online Diag EEM
155 0 65708 184536 32924 0 0 PM Callback
156 0 159252 132156 52004 2340 0 VLAN Manager
157 0 180 180 32924 0 0 dhcp snooping sw
158 0 180 180 32924 0 0 VTP Trap Process
160 0 216 0 33140 0 0 DATA Transfer Pr
161 0 216 0 33140 0 0 DATA Collector
162 2 72472 67736 65708 0 0 Virtual Exec
163 0 180 180 32924 0 0 AAA SEND STOP EV
164 0 0 0 32924 0 0 Syslog Traps
165 0 216 0 33140 0 0 Online Diag CNS
166 0 216 0 33140 0 0 Online Diag CNS
167 0 180 180 32924 0 0 SPAN switch
168 0 145100 0 178024 0 0 EEM Server
169 0 3724 0 39648 0 0 EEM ED POWERNET
170 0 0 0 32924 0 0 IP SLAs MPLSLM P
171 0 0 0 32924 0 0 IP SLAs Ethernet
172 0 0 0 32924 0 0 IP SLAs AutoEthe
173 0 3792 3792 38924 0 0 Syslog
174 0 98656 22032 95356 0 0 Call Home proces
175 0 9676 832 41768 0 0 EEM Policy Direc
176 0 3724 0 39648 0 0 EEM ED CLI
177 0 3724 0 39648 0 0 EEM ED Config
178 0 3724 0 39648 0 0 EEM ED Counter
179 0 3724 0 39648 0 0 EEM ED Env
180 0 3724 0 39648 0 0 EM ED GOLD
181 0 3724 0 39648 0 0 EEM ED Interface
182 0 3724 0 39648 0 0 EEM ED IOSWD
183 0 3724 0 39648 0 0 EEM ED None
184 0 3724 0 39648 0 0 EEM ED OIR
185 0 3956 72 39808 0 0 EEM ED RF
186 0 3724 0 39648 0 0 EEM ED SNMP
187 0 3724 0 39648 0 0 EEM ED Snmp_Prox
188 0 3724 0 39648 0 0 EEM ED Test
189 0 3724 0 39648 0 0 EEM ED Timer
190 0 0 0 35924 0 0 IPv6 RIB Event H
191 3 2098184 2047928 111180 0 0 Virtual Exec
193 0 0 0 32924 0 0 SNMP Timers
194 0 31299252 31298376 39800 0 0 IP SNMP
195 0 25161968 0 38924 0 0 PDU DISPATCHER
196 0 479499560 504539420 161032 0 0 SNMP ENGINE
197 0 1072 180 39816 0 0 IP SNMPV6
198 0 0 0 38924 0 0 SNMP ConfCopyPro
199 0 0 0 38924 0 0 SNMP Traps
200 0 0 0 29948 0 0 System polling
201 0 0 0 32924 0 0 DHCPD Timer
202 0 248 0 33172 0 0 DHCPD Database
156346160 Total
------------------ show process cpu ------------------
CPU utilization for five seconds: 26%/0%; one minute: 34%; five minutes: 34%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
1 0 10 0 0.00% 0.00% 0.00% 0 Chunk Manager
2 8 1461 5 0.00% 0.00% 0.00% 0 Load Meter
3 0 1 0 0.00% 0.00% 0.00% 0 CEF RP IPC Backg
4 0 1 0 0.00% 0.00% 0.00% 0 Deferred Events
5 0 1 0 0.00% 0.00% 0.00% 0 Retransmission o
6 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Receive
7 10996 1176 9350 0.00% 0.16% 0.13% 0 Check heaps
8 0 1 0 0.00% 0.00% 0.00% 0 Pool Manager
9 0 2 0 0.00% 0.00% 0.00% 0 Timers
10 32 3 10666 0.00% 0.00% 0.00% 0 PrstVbl
11 0 2 0 0.00% 0.00% 0.00% 0 Serial Backgroun
12 0 1 0 0.00% 0.00% 0.00% 0 Crash writer
13 0 1 0 0.00% 0.00% 0.00% 0 ifIndex Receive
14 297168 854120 347 2.79% 3.56% 3.24% 0 ARP Input
15 0 1 0 0.00% 0.00% 0.00% 0 CEF MIB API
16 0 1 0 0.00% 0.00% 0.00% 0 AAA_SERVER_DEADT
17 0 2 0 0.00% 0.00% 0.00% 0 AAA high-capacit
18 0 1 0 0.00% 0.00% 0.00% 0 Policy Manager
19 12 7 1714 0.00% 0.00% 0.00% 0 Entity MIB API
20 0 24 0 0.00% 0.00% 0.00% 0 EEM ED Syslog
21 0 1 0 0.00% 0.00% 0.00% 0 IFS Agent Manage
22 0 122 0 0.00% 0.00% 0.00% 0 IPC Dynamic Cach
23 0 1 0 0.00% 0.00% 0.00% 0 IPC Zone Manager
24 0 7307 0 0.00% 0.00% 0.00% 0 IPC Periodic Tim
25 0 1 0 0.00% 0.00% 0.00% 0 IPC Managed Time
26 8 7307 1 0.00% 0.00% 0.00% 0 IPC Deferred Por
27 0 1 0 0.00% 0.00% 0.00% 0 IPC Seat Manager
28 0 1 0 0.00% 0.00% 0.00% 0 IPC Session Serv
29 0 1 0 0.00% 0.00% 0.00% 0 client_entity_se
30 0 1 0 0.00% 0.00% 0.00% 0 SERIAL A'detect
31 0 1 0 0.00% 0.00% 0.00% 0 ARP Snoop
32 0 7307 0 0.00% 0.00% 0.00% 0 Dynamic ARP Insp
33 20 7297 2 0.00% 0.00% 0.00% 0 GraphIt
34 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd
35 36 5425 6 0.00% 0.00% 0.00% 0 Net Background
36 568 7305 77 0.07% 0.07% 0.07% 0 IDB Work
37 0 14 0 0.00% 0.00% 0.00% 0 Logger
38 16 7293 2 0.00% 0.00% 0.00% 0 TTY Background
39 12 7462 1 0.00% 0.00% 0.00% 0 Per-Second Jobs
40 3416 229 14917 0.00% 0.02% 0.00% 0 Per-minute Jobs
41 8 10 800 0.00% 0.00% 0.00% 0 IF-MGR control p
42 0 109 0 0.00% 0.00% 0.00% 0 IF-MGR event pro
43 0 1 0 0.00% 0.00% 0.00% 0 ISSU PROCESS IPC
44 0 1 0 0.00% 0.00% 0.00% 0 PrstVbl IPC Msg
45 0 2 0 0.00% 0.00% 0.00% 0 cpf_msg_holdq_pr
46 0 1 0 0.00% 0.00% 0.00% 0 cpf_msg_rcvq_pro
47 0 2 0 0.00% 0.00% 0.00% 0 IP Host Track HA
48 0 2 0 0.00% 0.00% 0.00% 0 ARP HA
49 0 1 0 0.00% 0.00% 0.00% 0 IP Admission HA
50 0 1 0 0.00% 0.00% 0.00% 0 Network-rf Notif
51 890568 4657385 191 14.79% 14.70% 15.47% 0 Cat4k Mgmt HiPri
52 718272 917177 783 6.00% 11.37% 11.08% 0 Cat4k Mgmt LoPri
53 72 7154 10 0.00% 0.00% 0.00% 0 Galios Reschedul
54 0 2 0 0.00% 0.00% 0.00% 0 IOS ACL Helper
55 0 13 0 0.00% 0.00% 0.00% 0 BACK CHECK
56 4 2 2000 0.00% 0.00% 0.00% 0 rf task
57 0 1 0 0.00% 0.00% 0.00% 0 RF High Priority
58 20 1446 13 0.00% 0.00% 0.00% 0 Net Input
59 48 1889 25 0.00% 0.00% 0.00% 0 Compute load avg
60 0 1 0 0.00% 0.00% 0.00% 0 cpf_process_tpQ
61 0 1 0 0.00% 0.00% 0.00% 0 AggMgr Process
62 0 8 0 0.00% 0.00% 0.00% 0 Transport Port A
63 4 2192 1 0.00% 0.00% 0.00% 0 HC Counter Timer
64 0 1 0 0.00% 0.00% 0.00% 0 SFF8472
65 0 2 0 0.00% 0.00% 0.00% 0 Ethernet OAM Pro
66 0 1 0 0.00% 0.00% 0.00% 0 PPPOE IA
67 0 2 0 0.00% 0.00% 0.00% 0 REP Topology cha
68 0 14 0 0.00% 0.00% 0.00% 0 Auth Manager
69 0 2 0 0.00% 0.00% 0.00% 0 Dot1x Mgr Proces
70 0 1 0 0.00% 0.00% 0.00% 0 MAB Framework
71 0 1 0 0.00% 0.00% 0.00% 0 AUTH POLICY Fram
72 0 1 0 0.00% 0.00% 0.00% 0 802.1x Webauth F
73 0 14 0 0.00% 0.00% 0.00% 0 802.1x switch
74 124 9457 13 0.07% 0.00% 0.00% 0 DTP Protocol
75 0 1 0 0.00% 0.00% 0.00% 0 EAP Framework
76 0 122 0 0.00% 0.00% 0.00% 0 Port-Security
77 0 2 0 0.00% 0.00% 0.00% 0 Ethernet CFM
78 16 7322 2 0.00% 0.00% 0.00% 0 Ethernet Timer C
79 0 2 0 0.00% 0.00% 0.00% 0 EFP Errd
80 12 7306 1 0.00% 0.00% 0.00% 0 UDLD
81 0 2 0 0.00% 0.00% 0.00% 0 IP Host Track Pr
82 0 1 0 0.00% 0.00% 0.00% 0 Switch Backup In
83 0 122 0 0.00% 0.00% 0.00% 0 MMN bkgrd proces
84 0 1 0 0.00% 0.00% 0.00% 0 powernet proxy t
85 12 1510 7 0.00% 0.00% 0.00% 0 powernet proxy u
86 4 732 5 0.00% 0.00% 0.00% 0 Ethchnl
87 0 2 0 0.00% 0.00% 0.00% 0 AAA Server
88 0 1 0 0.00% 0.00% 0.00% 0 AAA ACCT Proc
89 0 1 0 0.00% 0.00% 0.00% 0 ACCT Periodic Pr
90 0 1 0 0.00% 0.00% 0.00% 0 AAA System Acct
91 0 1 0 0.00% 0.00% 0.00% 0 Auth-proxy AAA B
92 0 25 0 0.00% 0.00% 0.00% 0 IP Admin SM Proc
93 7396 7847 942 0.07% 0.13% 0.12% 0 CDP Protocol
94 64 73 876 0.00% 0.00% 0.00% 0 SpanTree Helper
95 0 124 0 0.00% 0.00% 0.00% 0 Call Home Timer
96 0 2 0 0.00% 0.00% 0.00% 0 AAA Dictionary R
97 0 61 0 0.00% 0.00% 0.00% 0 DHCP Snooping
98 0 2 0 0.00% 0.00% 0.00% 0 EAPoUDP Process
99 0 3 0 0.00% 0.00% 0.00% 0 CEF switching ba
100 45272 1179096 38 0.39% 0.52% 0.53% 0 IP Input
101 0 1 0 0.00% 0.00% 0.00% 0 ICMP event handl
102 16 14240 1 0.00% 0.00% 0.00% 0 IP ARP Track
103 8 19 421 0.00% 0.00% 0.00% 0 ADJ resolve proc
104 0 1 0 0.00% 0.00% 0.00% 0 IPv6 Echo event
105 212 1666 127 0.00% 0.00% 0.00% 0 Collection proce
106 1028 14674 70 0.00% 0.02% 0.01% 0 Spanning Tree
107 0 163 0 0.00% 0.00% 0.00% 0 CEF background p
108 0 1 0 0.00% 0.00% 0.00% 0 IP IRDP
109 0 3 0 0.00% 0.00% 0.00% 0 XDR mcast
110 0 1 0 0.00% 0.00% 0.00% 0 IPC LC Message H
111 0 1 0 0.00% 0.00% 0.00% 0 XDR RP Ping Back
112 0 61 0 0.00% 0.00% 0.00% 0 XDR RP backgroun
113 0 1 0 0.00% 0.00% 0.00% 0 XDR RP Test Back
114 4 427 9 0.00% 0.00% 0.00% 0 TCP Timer
115 0 9 0 0.00% 0.00% 0.00% 0 TCP Protocols
116 0 1576 0 0.00% 0.00% 0.00% 0 Socket Timers
117 0 27 0 0.00% 0.00% 0.00% 0 HTTP CORE
118 0 94 0 0.00% 0.00% 0.00% 0 Cluster L2
119 0 731 0 0.00% 0.00% 0.00% 0 Cluster RARP
120 0 1 0 0.00% 0.00% 0.00% 0 COPS
121 0 1 0 0.00% 0.00% 0.00% 0 Probe Input
122 0 5 0 0.00% 0.00% 0.00% 0 RARP Input
123 0 2 0 0.00% 0.00% 0.00% 0 REP LSL Proc
124 0 2 0 0.00% 0.00% 0.00% 0 REP BPA/EPA Proc
125 0 1 0 0.00% 0.00% 0.00% 0 Critical Auth
126 0 46 0 0.00% 0.00% 0.00% 0 L2MM
127 4 128 31 0.00% 0.00% 0.00% 0 MRD
128 21460 325331 65 0.23% 0.26% 0.27% 0 IGMPSN
129 8 245 32 0.00% 0.00% 0.00% 0 IGMPQR
130 4 38 105 0.00% 0.00% 0.00% 0 MLDSN L2MCM
131 0 1 0 0.00% 0.00% 0.00% 0 MRD
132 0 1 0 0.00% 0.00% 0.00% 0 MLD_SNOOP
133 0 2 0 0.00% 0.00% 0.00% 0 L2TRACE SERVER
134 0 1 0 0.00% 0.00% 0.00% 0 IGMPSN-HA
135 0 1 0 0.00% 0.00% 0.00% 0 DHCP Snooping HA
136 0 2 0 0.00% 0.00% 0.00% 0 ATIP_UDP_TSK
137 24 242 99 0.00% 0.00% 0.00% 0 IP Background
138 4 4 1000 0.00% 0.00% 0.00% 0 IP RIB Update
139 15108 117908 128 0.07% 0.15% 0.15% 0 DHCPD Receive
140 0 1 0 0.00% 0.00% 0.00% 0 HSRP HA
141 22676 24439 927 0.63% 0.63% 0.63% 0 CEF: IPv4 proces
142 0 2 0 0.00% 0.00% 0.00% 0 ADJ background
143 0 1 0 0.00% 0.00% 0.00% 0 CFMPAL Process
144 0 1 0 0.00% 0.00% 0.00% 0 EPM MAIN PROCESS
145 0 1 0 0.00% 0.00% 0.00% 0 EM Background Pr
146 0 2 0 0.00% 0.00% 0.00% 0 LOCAL AAA
147 0 2 0 0.00% 0.00% 0.00% 0 ENABLE AAA
148 0 2 0 0.00% 0.00% 0.00% 0 LINE AAA
150 0 2 0 0.00% 0.00% 0.00% 0 TPLUS
151 0 2 0 0.00% 0.00% 0.00% 0 VTPMIB EDIT BUFF
152 0 2 0 0.00% 0.00% 0.00% 0 DHCP Security He
153 0 2 0 0.00% 0.00% 0.00% 0 DiagCard1/-1
154 0 2 0 0.00% 0.00% 0.00% 0 Online Diag EEM
155 100 32163 3 0.00% 0.00% 0.00% 0 PM Callback
156 8 3 2666 0.00% 0.00% 0.00% 0 VLAN Manager
157 0 609 0 0.00% 0.00% 0.00% 0 dhcp snooping sw
158 0 3 0 0.00% 0.00% 0.00% 0 VTP Trap Process
160 0 1 0 0.00% 0.00% 0.00% 0 DATA Transfer Pr
161 0 1 0 0.00% 0.00% 0.00% 0 DATA Collector
162 96 237 405 0.00% 0.00% 0.00% 2 Virtual Exec
163 0 2 0 0.00% 0.00% 0.00% 0 AAA SEND STOP EV
164 0 1 0 0.00% 0.00% 0.00% 0 Syslog Traps
165 0 1 0 0.00% 0.00% 0.00% 0 Online Diag CNS
166 0 1 0 0.00% 0.00% 0.00% 0 Online Diag CNS
167 0 3 0 0.00% 0.00% 0.00% 0 SPAN switch
168 0 46 0 0.00% 0.00% 0.00% 0 EEM Server
169 0 2 0 0.00% 0.00% 0.00% 0 EEM ED POWERNET
170 0 356 0 0.00% 0.00% 0.00% 0 IP SLAs MPLSLM P
171 0 1 0 0.00% 0.00% 0.00% 0 IP SLAs Ethernet
172 0 1 0 0.00% 0.00% 0.00% 0 IP SLAs AutoEthe
173 0 8 0 0.00% 0.00% 0.00% 0 Syslog
174 0 2 0 0.00% 0.00% 0.00% 0 Call Home proces
175 0 2 0 0.00% 0.00% 0.00% 0 EEM Policy Direc
176 0 3 0 0.00% 0.00% 0.00% 0 EEM ED CLI
177 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Config
178 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Counter
179 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Env
180 0 3 0 0.00% 0.00% 0.00% 0 EM ED GOLD
181 4 3 1333 0.00% 0.00% 0.00% 0 EEM ED Interface
182 0 3 0 0.00% 0.00% 0.00% 0 EEM ED IOSWD
183 0 3 0 0.00% 0.00% 0.00% 0 EEM ED None
184 0 3 0 0.00% 0.00% 0.00% 0 EEM ED OIR
185 4 3 1333 0.00% 0.00% 0.00% 0 EEM ED RF
186 0 3 0 0.00% 0.00% 0.00% 0 EEM ED SNMP
187 0 2 0 0.00% 0.00% 0.00% 0 EEM ED Snmp_Prox
188 0 3 0 0.00% 0.00% 0.00% 0 EEM ED Test
189 4 184 21 0.00% 0.00% 0.00% 0 EEM ED Timer
190 0 3 0 0.00% 0.00% 0.00% 0 IPv6 RIB Event H
191 916 1189 770 0.15% 0.01% 0.00% 3 Virtual Exec
193 0 2 0 0.00% 0.00% 0.00% 0 SNMP Timers
194 22896 226747 100 0.00% 0.23% 0.22% 0 IP SNMP
195 4420 101730 43 0.00% 0.05% 0.05% 0 PDU DISPATCHER
196 89864 113497 791 0.00% 1.15% 1.23% 0 SNMP ENGINE
197 0 2 0 0.00% 0.00% 0.00% 0 IP SNMPV6
198 0 1 0 0.00% 0.00% 0.00% 0 SNMP ConfCopyPro
199 0 1 0 0.00% 0.00% 0.00% 0 SNMP Traps
200 8 3649 2 0.00% 0.00% 0.00% 0 System polling
201 0 61 0 0.00% 0.00% 0.00% 0 DHCPD Timer
202 0 128 0 0.00% 0.00% 0.00% 0 DHCPD Database
------------------ show process cpu history ------------------
2223333344444333334444433333222223333333333333333333333333
6661111144444999991111177777777770000022222222222222233333
100
90
80
70
60
50
40 ********************
30 **********************************************************
20 **********************************************************
10 **********************************************************
0....5....1....1....2....2....3....3....4....4....5....5....
0 5 0 5 0 5 0 5 0 5
CPU% per second (last 60 seconds)
4444344444443444444444443444444544444444454444444444444443
1430565570859234044300148353494089663739605653587669337329
100
90
80
70
60
50 **** ** * * ***** * ****** ****** *
40 *#***##*#*#***#*##********#*########################*###**
30 ##########################################################
20 ##########################################################
10 ##########################################################
0 5 0 5 0 5 0 5 0 5
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
57
00
100
90
80
70 *
60 *
50 **
40 #*
30 ##
20 ##
10 ##
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
开机自检各项硬件状态看起来也是正常的
------------------ show diagnostic result module all detail ------------------
Current bootup diagnostic level: minimal
module 1: SerialNo : FOX1330GM8Y
Overall Diagnostic Result for module 1 : PASS
Diagnostic level at card bootup: minimal
Test results: (. = Pass, F = Fail, U = Untested)
___________________________________________________________________________
1) supervisor-bootup ---------------> .
Error code ------------------> 0 (DIAG_SUCCESS)
Total run count -------------> 1
Last test testing type ------> n/a
Last test execution time ----> Jun 13 2016 22:33:12
First test failure time -----> n/a
Last test failure time ------> n/a
Last test pass time ---------> Jun 13 2016 22:33:12
Total failure count ---------> 0
Consecutive failure count ---> 0
Power-On-Self-Test Results for ACTIVE Supervisor
Power-on-self-test for Module 1: WS-C4948-10GE
Port/Test Status: (. = Pass, F = Fail, U = Untested)
Cpu Subsystem Tests ...
seeprom: . temperature_sensor: .
Port Traffic: L3 Serdes Loopback ...
0: . 1: . 2: . 3: . 4: . 5: . 6: . 7: . 8: . 9: . 10: . 11: .
12: . 13: . 14: . 15: . 16: . 17: . 18: . 19: . 20: . 21: . 22: . 23: .
24: . 25: . 26: . 27: . 28: . 29: . 30: . 31: . 32: . 33: . 34: . 35: .
36: . 37: . 38: . 39: . 40: . 41: . 42: . 43: . 44: . 45: . 46: . 47: .
62: . 63: .
Port Traffic: L2 Serdes Loopback ...
62: . 63: .
Port Traffic: L2 Asic Loopback ...
62: . 63: .
Switch Subsystem Memory ...
1: . 2: . 3: . 4: . 5: . 6: . 7: . 8: . 9: . 10: . 11: . 12: .
13: . 14: . 15: . 16: . 17: . 18: . 19: . 20: . 21: . 22: . 23: . 24: .
25: . 26: . 27: . 28: . 29: . 30: . 31: . 32: . 33: . 34: . 35: . 36: .
37: . 38: . 39: . 40: . 41: . 42: . 43: . 44: . 45: . 46: . 47: . 48: .
49: . 50: . 51: .
Module 1 Passed
2) packet-memory-bootup ------------> U
Error code ------------------> 3 (DIAG_SKIPPED)
Total run count -------------> 0
Last test execution time ----> n/a
Last test pass time ---------> n/a
packet buffers on free list: 64557 bad: 0 used for ongoing tests: 979
Exhaustive packet memory tests did not run at bootup.
Bootup test results:5
No errors.
3) packet-memory-ongoing -----------> U
Packet memory errors: 0 0
Current alert level: green
Per 5 seconds in the last minute:
0 0 0 0 0 0 0 0 0 0
0 0
Per minute in the last hour:
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
Per hour in the last day:
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0
Per day in the last 30 days:
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
Direct memory test failures per minute in the last hour:
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0
Potential false positives: 0 0
Ignored because of rx errors: 0 0
Ignored because of cdm fifo overrun: 0 0
Ignored because of oir: 0 0
Ignored because isl frames received: 0 0
Ignored during boot: 0 0
Ignored after writing hw stats: 0 0
Ignored on high gigaport: 0
Ongoing diag action mode: Normal
Last 1000 Memory Test Failures:
Last 1000 Packet Memory errors:
First 1000 Packet Memory errors:
4) linecard-online-diag ------------> .
Slot Ports Card Type Diag Status Diag Details
1 50 10/100/1000BaseT (RJ45), 10GE (X2) Sup Skipped Packet memory
Detailed Status
. = Pass U = Unknown
L = Loopback failure S = Stub failure
P = Port failure
E = SEEPROM failure G = GBIC integrity check failure
Ports 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
Ports 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
Ports 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
Ports 49 50
5) online-diag-tdr:
Port 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
U U U U U U U U U U U U U U U U U U U U U U U U
Port 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
Port 49 50
U U
Detailed Status
------------------ show environment ------------------
no alarm
Chassis Temperature = 55 degrees Celsius
Chassis Over Temperature Threshold = 75 degrees Celsius
Chassis Critical Temperature Threshold = 95 degrees Celsius
Power Fan Inline
Supply Model No Type Status Sensor Status
PS1 PWR-C49-300AC AC 300W good good n.a.
PS2 PWR-C49-300AC AC 300W good good n.a.
Power supplies needed by system : 1
Power supplies currently available : 2
Chassis Type : WS-C4948-10GE
Power consumed by backplane : 0 Watts
Switch Bandwidth Utilization : 12%
Supervisor Led Color : Green
Module 1 Status Led Color : Green
Fantray : Good
Fantray removal timeout : 240
Power consumed by Fantray : 30 Watts
------------------ show stacks ------------------
Minimum process stacks:
Free/Size Name
31700/32000 ISSU Infra API Delayed Registration Process
79372/86000 Routekernel Process
31716/32000 CDP BLOB
31580/32000 SPAN Subsystem
85088/86000 EEM Auto Registration Proc
31548/32000 SASL MAIN
30704/32000 Update prst
5348/12000 Init
34704/35000 cdp init process
31404/32000 RADIUS INITCONFIG
31660/32000 URPF stats
28716/29000 Rom Random Update Process
33148/36000 TCP Command
56348/60000 Virtual Exec
Interrupt level stacks:
Level Called Unused/Size Name
1 28 8412/9000 Level 1
2 0 9000/9000 Level 2
3 5571559 8124/9000 Level 3
4 2459 8836/9000 Level 4
5 1828762 8676/9000 Level 5
6 0 9000/9000 Level 6
7 0 9000/9000 Level 7
------------------ show platform crashdump ------------------
Last powerfail: 05/24/2013 06:10:08
Current time: 06/14/2016 00:34:53
Last reload status: 00000400 00000000
Last crash: 06/13/2016 22:32:25
Build: 12.2(52)SG ENTSERVICES
buildversion addr: 129473FC
pc=101DCF2C lr=101DB770 msr=02029230 vector=00000D00
cr=42000024 ctr=00000000 xer=20000000
r0=101DB770 r1=13C0E818 r2=00000000 r3=13146684
r4=00000000 r5=00000000 r6=00000000 r7=00000000
r8=00000004 r9=00000001 r10=13C0E884 r11=00000000
r12=65679370 r13=00000000 r14=1083D5B4 r15=00000000
r16=00000000 r17=00000000 r18=00000000 r19=00000000
r20=00000000 r21=00000000 r22=00000000 r23=00000000
r24=00000000 r25=00000000 r26=1721CA80 r27=1B09CFB4
r28=281659E4 r29=13146684 r30=00000000 r31=13146684
dec=0002B5EF tbu=00000BCB tbl=1BCF9714
dar=80200020 dsisr=80200020 hid0=80004000
MCSR: 00000000
L1CSR0: 00010001 L1CSR1: 00010001
SRR0: 101DCF2C CSRR0: 00000000 MCSRR0: 00000000
CISR0: 00000000 CISR1: 00000000
PIC CTPR: 00000000 WHOAMI: 00000000 TCR: 00000100
L2 CaptDataHi: 00000000 CaptDataLo: 00000000 CaptEcc: 00000000
L2 ErrDet: 00000000 ErrDis: 00000000
L2 ErrInten: 00000019 ErrAttr: 00000000
L2 ErrAddr: 00000000 ErrCtl: 00000000
DDR ErrDetect: 00000000 ErrSbe: 00FF0000
DDR ErrAddr: 00000000 ErrAttrib: 00000000
DDR ErrDataLow: 00000000 ErrDataHi: 00000000 ErrEcc: 00000000
ECM EEBACR: 00000003 EEBPCR: 01000000
ECM EEDR: 00000000 EEER: 00000001
ECM EEATR: 00000000 EEADR: 00000000
PCI ErrAddr: 00000000 ErrExtAddr: 00000000 ErrDl: 00000000 ErrDh: 00000000
PCI ErrDr: 00000000 ErrAttrib: 00000000
PCI ErrCapDr: 00000200 ErrEn: 000005FF
Machine Check Interrupt Count: 0
L1 Instruction Cache Parity Errors: 0
L1 Instruction Cache Parity Errors (CPU30): 0
L1 Data Cache Parity Errors: 0
Traceback: 101DCF2C 101DB770 101DB68C 10C9E0C8 10C9E460 111336E0 10E34848 10E6EC3C 10E72120 1083D6D0 108028A4 107F9A24
Stack frames:
Frame 1: pc=101DB770 stack=13C0E830
Frame 2: pc=101DB68C stack=13C0E858
Frame 3: pc=10C9E0C8 stack=13C0E860
Frame 4: pc=10C9E460 stack=13C0E868
Frame 5: pc=111336E0 stack=13C0E870
Frame 6: pc=10E34848 stack=13C0E8B0
Frame 7: pc=10E6EC3C stack=13C0E8C8
Frame 8: pc=10E72120 stack=13C0E948
Frame 9: pc=1083D6D0 stack=13C0E990
Frame 10: pc=108028A4 stack=13C0E9D0
Frame 11: pc=107F9A24 stack=13C0E9D8
Pushed stack:
13C0E810: 13C0E830 13C0E850
13C0E820: 281659E4 13146684 00000000 1B57EA84
13C0E830: 13C0E858 101DB770 13C0E840 10C9E47C
13C0E840: 13C0E860 111336FC 13C0E8B8 13C0E880
13C0E850: 281659E4 1B52914C 13C0E860 101DB68C
13C0E860: 13C0E868 10C9E0C8 13C0E870 10C9E460
13C0E870: 13C0E8B0 111336E0 1B09CFB4 2816010C
13C0E880: 01040000 281659E4 00000000 00000000
13C0E890: 00000000 00000000 00000000 1B09CFB4
13C0E8A0: 16A8459E 16A8459C 281659E4 00000000
13C0E8B0: 13C0E8C8 10E34848 00000000 00000001
13C0E8C0: 12950000 16A8458E 13C0E948 10E6EC3C
13C0E8D0: 13C0E8E0 171820C0 00000000 172FC978
13C0E8E0: 13C0E970 00000000 00000000 12150000
13C0E8F0: 171820C0 171820C0 00000000 17507D04
13C0E900: 00000000 00000000 00000000 00000000
13C0E910: 13C0E918 00000000 13C0E948 00000000
13C0E920: 00000000 00000000 00000000 00000000
13C0E930: 00000000 12150000 12BC0000 12950000
13C0E940: 00000013 1721CA80 13C0E990 10E72120
13C0E950: 13C0E968 12150000 12BC0000 12950000
13C0E960: 00000012 12BC0000 13C0E970 107FA9BC
13C0E970: 13C0E988 116DBC88 13C0E990 12950000
13C0E980: 00000013 12950000 00000013 1721CA80
13C0E990: 13C0E9D0 1083D6D0 00000000 173050CC
13C0E9A0: 00000002 1B0268CC 00000000 00000002
13C0E9B0: 00000000 FFFFFFFF FFFFFFFF 00000000
13C0E9C0: 00000000 00000000 00000000 00000000
13C0E9D0: 13C0E9D8 108028A4 00000000 107F9A24
13C0E9E0: FFFFFFFF
Popped stack:
13C0E610: 00000000 00010030
13C0E620: 13C0E638 00000000 00000000 28160103
13C0E630: 1B09CFB4 13C0E7C8 13C0E658 10E745BC
13C0E640: 1B09CFB4 13C0E698 13C0E69C 13C0E7C8
13C0E650: 1B09CFB4 13C0E7C8 13C0E660 10E68710
13C0E660: 13C0E680 10C1D9DC 13C0E800 00000000
13C0E670: 1BCED718 00000007 13C0E690 12AAB0C8
13C0E680: 13C0E690 13C0E6F0 1B748A6C 1B09CFB4
13C0E690: 13C0E6A0 10284F50 1405C868 1B748AB0
13C0E6A0: 13C0E6A8 102B361C 13C0E6E8 11083490
13C0E6B0: 13C0E8C8 42000022 13C0E838 281624A6
13C0E6C0: 1B75E070 00000000 00000001 00000000
13C0E6D0: 00000000 1B75E070 1B748A6C 281624A6
13C0E6E0: 00000000 1B7582BC 13C0E760 110814CC
13C0E6F0: 00000000 281624A6 00000007 13C0E770
13C0E700: 13C0E774 1C156560 13C0E720 10827328
13C0E710: 00000006 22000044 13C0E834 13C0E8F8
13C0E720: 13C0E8F4 13C0E830 28160103 28160103
13C0E730: 1B09CFB4 281624A6 13C0E968 00000000
13C0E740: 00000000 13C0E7D4 00000000 00000000
13C0E750: 00000000 281624A6 13C0E838 00000000
13C0E760: 13C0E768 110817A8 13C0E798 110BA35C
13C0E770: 1B748A6C 1B748A6C 13C0E790 00000000
13C0E780: 281624A6 281624A6 00000000 13C0E7D8
13C0E790: 00000000 13C0E838 13C0E7A0 117D5F28
13C0E7A0: 13C0E7E0 117D5FB4 13C0E840 28160103
13C0E7B0: 13C0E7D8 281624A6 42000024 00000000
13C0E7C0: 281624A6 281624A6 13C0E958 1B09CFB4
13C0E7D0: 281624A6 00000000 13C0E870 110806F0
13C0E7E0: 13C0E7F0 11082A28 13C0E800 13C0E810
13C0E7F0: 13C0E800 1B09CFB4 13C0E868 1B57EA84
13C0E800: 13C0E828 101DB734 13C0E820 00000001
13C0E810: 13C0E830 281624A6
Log buffer:
1:06 GTM Thu Jun 9 2016
CMD: 'sh int ip int' 13:51:11 GTM Thu Jun 9 2016
CMD: 'sh int ip bir' 13:51:13 GTM Thu Jun 9 2016
CMD: 'sh int ip bri' 13:51:15 GTM Thu Jun 9 2016
CMD: 'sh ip int bri' 13:51:19 GTM Thu Jun 9 2016
CMD: 'sh ip int brief ' 13:51:20 GTM Thu Jun 9 2016
CMD: 'sh run' 13:51:46 GTM Thu Jun 9 2016
CMD: 'dis stp bri' 13:52:43 GTM Thu Jun 9 2016
CMD: 'sh stp ' 13:52:47 GTM Thu Jun 9 2016
CMD: 'sh spa' 13:52:52 GTM Thu Jun 9 2016
CMD: 'sh spanning-tree ' 13:52:53 GTM Thu Jun 9 2016
CMD: 'sh spanning-tree bri' 13:52:55 GTM Thu Jun 9 2016
CMD: 'sh spanning-tree bridge ' 13:52:55 GTM Thu Jun 9 2016
CMD: 'sh spa' 13:53:02 GTM Thu Jun 9 2016
CMD: 'sh spanning-tree ' 13:53:02 GTM Thu Jun 9 2016
CMD: 'ping 40.22.0.253' 13:53:26 GTM Thu Jun 9 2016
CMD: 'ping 40.22.0.252' 13:53:29 GTM Thu Jun 9 2016
CMD: 'ping 40.22.0.251' 13:53:32 GTM Thu Jun 9 2016
CMD: 'sh run' 13:53:40 GTM Thu Jun 9 2016
CMD: 'sh ip int' 13:53:46 GTM Thu Jun 9 2016
CMD: 'sh ip interface bri' 13:53:47 GTM Thu Jun 9 2016
CMD: 'sh ip interface brief ' 13:53:47 GTM Thu Jun 9 2016
CMD: 'dis u' 13:53:52 GTM Thu Jun 9 2016
CMD: 'sh run' 13:53:54 GTM Thu Jun 9 2016
CMD: 'ping 201.201.3.2' 13:54:21 GTM Thu Jun 9 2016
CMD: 'ping 201.201.3.1' 13:54:26 GTM Thu Jun 9 2016
CMD: 'sh run' 13:54:32 GTM Thu Jun 9 2016
CMD: 'en' 14:27:45 GTM Thu Jun 9 2016
CMD: 'sh en' 14:27:53 GTM Thu Jun 9 2016
CMD: 'sh env' 14:27:54 GTM Thu Jun 9 2016
CMD: 'sh environment t' 14:27:55 GTM Thu Jun 9 2016
CMD: 'sh environment temperature ' 14:27:55 GTM Thu Jun 9 2016
CMD: 'exit' 14:28:00 GTM Thu Jun 9 2016
CMD: 'en' 02:04:27 GTM Fri Jun 10 2016
CMD: 'sh ver' 02:04:30 GTM Fri Jun 10 2016
CMD: 'sh version ' 02:04:30 GTM Fri Jun 10 2016
CMD: 'en' 15:07:21 GTM Fri Jun 10 2016
CMD: 'show vl' 15:07:27 GTM Fri Jun 10 2016
CMD: 'show vlan bri' 15:07:28 GTM Fri Jun 10 2016
CMD: 'show vlan brief ' 15:07:28 GTM Fri Jun 10 2016
CMD: 'ping 10.18.5.55' 15:07:36 GTM Fri Jun 10 2016
CMD: 'show mac add' 15:08:53 GTM Fri Jun 10 2016
CMD: 'show mac address-table ' 15:08:54 GTM Fri Jun 10 2016
CMD: 'show mac address-table | in' 15:09:03 GTM Fri Jun 10 2016
CMD: 'show mac address-table | include 6fb2' 15:09:09 GTM Fri Jun 10 2016
CMD: 'show' 15:09:14 GTM Fri Jun 10 2016
CMD: 'show vl' 15:09:14 GTM Fri Jun 10 2016
CMD: 'show vlan bri' 15:09:15 GTM Fri Jun 10 2016
CMD: 'show vlan brief ' 15:09:16 GTM Fri Jun 10 2016
CMD: 'show' 15:09:27 GTM Fri Jun 10 2016
CMD: 'show logg' 15:09:28 GTM Fri Jun 10 2016
CMD: 'show logging ' 15:09:29 GTM Fri Jun 10 2016
CMD: 'show' 15:09:58 GTM Fri Jun 10 2016
CMD: 'show mac add' 15:10:01 GTM Fri Jun 10 2016
CMD: 'show mac address-table | in' 15:10:04 GTM Fri Jun 10 2016
CMD: 'show mac address-table | include error' 15:10:09 GTM Fri Jun 10 2016
*Jun 10 16:33:47: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: Packet received with invalid source MAC address (00:00:00:00:00:00) on port Te1/50 in vlan 1CMD: 'en' 09:12:39 GTM Sun Jun 12 2016
CMD: 'sh int' 09:12:42 GTM Sun Jun 12 2016
CMD: 'sh interfaces st' 09:12:43 GTM Sun Jun 12 2016
CMD: 'sh interfaces statu' 09:12:44 GTM Sun Jun 12 2016
CMD: 'sh interfaces status ' 09:12:44 GTM Sun Jun 12 2016
CMD: 'sh vl br' 09:13:13 GTM Sun Jun 12 2016
CMD: 'sh vl brief ' 09:13:14 GTM Sun Jun 12 2016
CMD: 'sh ru' 09:13:24 GTM Sun Jun 12 2016
CMD: 'sh running-config ' 09:13:25 GTM Sun Jun 12 2016
CMD: 'sh int' 09:13:34 GTM Sun Jun 12 2016
CMD: 'sh interfaces st' 09:13:35 GTM Sun Jun 12 2016
CMD: 'sh interfaces statu' 09:13:35 GTM Sun Jun 12 2016
CMD: 'sh interfaces status ' 09:13:41 GTM Sun Jun 12 2016
CMD: 'sh ru' 09:13:54 GTM Sun Jun 12 2016
CMD: 'sh running-config ' 09:13:55 GTM Sun Jun 12 2016
Malloc / Free trace:
1 . pc=105F0280 addr=1C76C800
2 . pc=117AA780 addr=1C7BFC9C
3 . pc=117AA778 addr=13174400
4 . pc=117AA630 addr=13174400
5 . pc=30000010 addr=13174400
6 . pc=117AA5FC addr=1C7BFC9C
7 . pc=3000001E addr=1C7BFC9C
8 . pc=117AA780 addr=1C7BFC9C
9 . pc=117AA778 addr=13174400
10. pc=117AA630 addr=13174400
11. pc=30000010 addr=13174400
12. pc=117AA5FC addr=1C7BFC9C
13. pc=3000001E addr=1C7BFC9C
14. pc=117AA780 addr=1C7BFC9C
15. pc=117AA778 addr=13174400
16. pc=117AA630 addr=13174400
17. pc=30000010 addr=13174400
18. pc=117AA5FC addr=1C7BFC9C
19. pc=3000001E addr=1C7BFC9C
20. pc=117AA780 addr=1C7BFC9C
21. pc=117AA778 addr=13174400
22. pc=117AA630 addr=13174400
23. pc=30000010 addr=13174400
24. pc=117AA5FC addr=1C7BFC9C
25. pc=3000001E addr=1C7BFC9C
26. pc=117AA780 addr=1C7BFC9C
27. pc=117AA778 addr=13174400
28. pc=117AA630 addr=13174400
29. pc=30000010 addr=13174400
30. pc=117AA5FC addr=1C7BFC9C
31. pc=3000001E addr=1C7BFC9C
32. pc=117AA780 addr=1C7BFC9C
33. pc=117AA778 addr=13174400
34. pc=117AA630 addr=13174400
35. pc=30000010 addr=13174400
36. pc=117AA5FC addr=1C7BFC9C
37. pc=3000001E addr=1C7BFC9C
38. pc=117AA780 addr=1C7BFC9C
39. pc=117AA778 addr=13174400
40. pc=117AA630 addr=13174400
41. pc=30000010 addr=13174400
42. pc=117AA5FC addr=1C7BFC9C
43. pc=3000001E addr=1C7BFC9C
44. pc=117AA780 addr=1C7BFC9C
45. pc=117AA778 addr=13174400
46. pc=117AA630 addr=13174400
47. pc=30000010 addr=13174400
48. pc=117AA5FC addr=1C7BFC9C
49. pc=3000001E addr=1C7BFC9C
50. pc=117AA780 addr=1C7BFC9C
51. pc=117AA778 addr=13174400
52. pc=117AA630 addr=13174400
53. pc=30000010 addr=13174400
54. pc=117AA5FC addr=1C7BFC9C
55. pc=3000001E addr=1C7BFC9C
56. pc=117AA780 addr=1C7BFC9C
57. pc=117AA778 addr=13174400
58. pc=117AA630 addr=13174400
59. pc=30000010 addr=13174400
60. pc=117AA5FC addr=1C7BFC9C
61. pc=3000001E addr=1C7BFC9C
62. pc=117AA780 addr=1C7BFC9C
63. pc=117AA778 addr=13174400
64. pc=117AA630 addr=13174400
交换机的crashinfo 一般是如何分析呢? 这一堆信息应该有专门的解码工具吧, 貌似思科官网上没有在线分析crashinfo的工具,一般人完全看不懂。
求大神来指点一下, 对于这种情况该如何处理呢?
1 个已接受解答
已接受的解答
pebao
你的设备里面有crashinfo文件么?这个文件自己肯定是看不懂的,需要有工程师用工具进行decode才能发现重启的原因。这个decode只有工程师有权限使用。
在原帖中查看解决方案
5 条回复5
pebao
niweijian2014
等大神出来
fortune
show log 没有的 ? 这里看到重启是reload 命令,看看日志
leimin fan
pebao 发表于 2016-6-16 10:15 back.gif
你的设备里面有crashinfo文件么?这个文件自己肯定是看不懂的,需要有工程师用工具进行decode才能发现重启的 ...
(⊙o⊙)哦, crashinfo只有TAC才可以decode哇,我看flash里有crashinfo这个目录但是里面没有文件... 那还就分析不了了, 我只有再观察一段时间了,谢谢!
pxhen
route#more bootflash:跟上错误日志文件名后回车
快捷链接
