取消
显示结果
搜索替代
您的意思是:
查看次数
26
有帮助
9
回复
CISCO4510报%C4K_HWPORTMAN-4-BLOCKEDTXQUEUE
suchuanrui
重启后恢复正常,但是经常反复。
show module 板卡引擎正常。
求指导!!!谢谢
1 个已接受解答
已接受的解答
Terence.Jh
9 条回复9
Terence.Jh
luodaheng1
BUG CSCuo62498
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuo62498/?rfs=iqvred
MF: C4948 %C4K_HWPORTMAN-4-BLOCKEDTXQUEUE: Blocked transmit queue
CSCuo62498
Description
Symptom:
C4948TxQ will block transmit after BusyBit counters keep increasing for a while.
Apr 11 00:26:21 84.38.34.230 8865: 008861: Apr 11 00:26:19.749 BST: %C4K_HWPORTMAN-3-TXQUEDRAINFAILURE: Failed to drain transmit queues on Switch Phyport Te1/5 using slot pool 65535
0016 ar20.englw Apr 11 00:29:51 84.38.34.230 8866: 008862: Apr 11 00:29:49.996 BST: %C4K_HWPORTMAN-4-BLOCKEDTXQUEUE: Blocked transmit queue HwTxQId7 on Switch Phyport Te1/5, count=1
Conditions:
This message can appear when the port in question is receiving pause
frames from the peer (see "show int gi x/y flow" on this port and the peer port).
show platform software int gi x/y all | inc Busy
shows an increasing BusyBitActivityCount as in
BusyBitActivityCount : 431
Workaround:
The port should recover and the message will not be seen when the pause frames from the peer are stopped. However they do not stop and the port is stuck permanently. Module reset is required to restore normal operation, even a shut / no shut of the affected port does not resolve.
Known Affected Releases: (1)
15.1(2)SGN3.4
No release planned to fix this bug
luodaheng1
CISCO目前没有计划修复这个BUG
suchuanrui
terence 发表于 2018-11-12 08:54
系统BUG,引擎升级到推荐版本https://quickview.cloudapps.cisco.com/quickview/bug/CSCuo62498
兄弟 们 我的版本是这个 如果没有计划修复可咋弄呀 两三天就出现一次两个板卡就不能用了
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICES-M), Version 12.2(53)SG2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 16-Mar-10 02:00 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x11F06F90
ROM: 12.2(31r)SGA2
Dagobah Revision 226, Swamp Revision 34
N4510-1 uptime is 41 weeks, 6 days, 17 hours, 21 minutes
Uptime for this control processor is 41 weeks, 6 days, 17 hours, 21 minutes
System image file is "bootflash:cat4500-entservices-mz.122-53.SG2.bin"
suchuanrui
luodaheng 发表于 2018-11-12 14:38
CISCO目前没有计划修复这个BUG
他是双引擎 我还想升级下版本来着
Terence.Jh
升级到推荐版本看看会不会有,如果没修复就只能等或者开CASE加急
suchuanrui
好的 我去下个版本 升级试试 还要写文档。。。。。
one-time
Level 13
Level 13
楼主,如问题已得到解决,请动动小手标记最佳答案哦~
Rockyw
Error Messages on Catalyst 4500/4000 Series Switches
%C4K_HWPORTMAN-4-BLOCKEDTXQUEUE:Blocked transmit queue HwTxQId[dec]on [char], count=[dec]
Problem
The switch generates %C4K_HWPORTMAN-4-BLOCKEDTXQUEUE:Blocked transmit queue HwTxQId[dec]on[char], count=[dec] errors.
Description
This rate-limited message indicates that a transmit queue on a port is blocked for reasons other than “paused”. In other words, the traffic on that port is being limited and blocked. You see the blocked transmit queue messages if the Supervisor Engine is not able to send packets to the line card because of the reception of a busy bit from the line card. Bad hardware or a speed/duplex mismatch can cause this problem. The workaround is to configure both sides of the link to autonegotiate for speed and duplex. Issue the shut/no shut command in order to recover the port. If the problem persists, move the connected device to another port and see if the problem happens there. As a final measure to unblock the transmit (Tx) queue, issue the hw-module reset command in order to reboot the switch or reset the line card.
%CDP-4-NVLANMISMATCH: Native vlan mismatch detected on port [dec]/[dec]
Problem
The switch generates frequent %CDP-4-NVLANMISMATCH syslog messages.
Description
This example shows the console output that you see when this error message occurs on the switch:
%CDP-4-NVLANMISMATCH:Native vlan mismatch detected on port 4/1
The switch generates this message whenever the switch port is physically connected to another switch or router. The switch generates this message because the configured native VLAN on the port is different than the native VLAN that is set on the connecting switch or router port.
A trunk port that you configure with IEEE 802.1Q tagging can receive both tagged and untagged traffic. By default, the switch forwards untagged traffic with the native VLAN that is configured for the port. If a packet has the same VLAN ID as the outgoing port native VLAN ID, the packet is transmitted untagged. If the VLAN IDs are not the same, the switch transmits the packet with a tag.
Ensure that the native VLAN for an 802.1Q trunk is the same on both ends of the trunk link. If the native VLAN on one end of the trunk is different than the native VLAN on the other end, the traffic of the native VLANs on both sides cannot be transmitted correctly on the trunk. This failure to transmit correctly can imply some connectivity issues in your network.
In order to verify the native VLAN that is configured on your switch, issue the show trunk mod/port command. In this command, mod/port is the trunk port. Here is sample output from the command:
Console> (enable) show trunk 5/24
Port Mode Encapsulation Status Native vlan
5/24 desirable dot1q not-trunking 1
Port Vlans allowed on trunk
5/24 1-1005
Port Vlans allowed and active in management domain
5/24 1
Port Vlans in spanning tree forwarding state and not pruned
5/24
Console> (enable)
In order to change the native VLAN that is configured on the trunk port, issue the set vlan vlan-id mod/port command. In this command, mod/port is the trunk port.
上述信息来源于下面的文档
Common CatOS Error Messages on Catalyst 4500/4000 Series Switches
https://www.cisco.com/c/en/us/su ... ches/30003-176.html
Rockyw | If it solves your problem, please mark as answer. Thanks !
快捷链接
